Help With Mac Headers
Old 02-07-2004, 11:23 PM
TAQuickness's Avatar
Default Help With Mac Headers
Has anyone put the Mac 3398's on a '00 TA? It look to me like the egr plumbing is not right? What needs to be done to make it work?
Old 02-07-2004, 11:28 PM
jrp
SN95 Director
jrp's Avatar
the 3398 header is for the 98-99 cars, they have a different air and egr position from the 00. you'll need the egr setup from the 98-99 or you can just !egr and !air all together and forget it, then just have the codes deleted.
Old 02-07-2004, 11:39 PM
SMOKIN01TA's Avatar
yep just delete them make things much nicer under there.
Old 02-08-2004, 12:58 AM
chrismcdaniel's Avatar
I had the same problem as you, I ordered for a oo ss and got the sameheaders as you i just cut everything to fit and thenused after market lines to reconct it, but as soon as my block offs get here im removing all of it because i just got the car tunned and had all that **** removed.
Old 02-08-2004, 08:37 AM
Where did you get your lines from & what did you use? I was thinking to hit the sears hardware plumbing section.
