If you run a wet kit do you need to upgrade injectors?
Old 02-07-2004, 11:27 PM
maddboost's Avatar
Default If you run a wet kit do you need to upgrade injectors?
I know if you run a wet kit you should upgrade your fuel pump. But do you also need to upgrade your injectors assuming you arent maxing them out when running N/A. Im guessing you shouldnt since your adding the extra fuel along with the N20 through the intake, but wanted to check with some of you nitrous veterans. I plan on running a TNT F2 kit on my new motor setup.
Old 02-08-2004, 01:31 AM
timbalan77's Avatar
No, you won't need new injectors. Regarding the fuel pump, it depends on how big of a shot you are talking about. Right around a 150 shot is where you should consider it, IMO.
Old 02-08-2004, 08:00 AM
ITSovr4U's Avatar
I agree with Timbalan77.
Old 02-08-2004, 09:28 PM
35th SS's Avatar
I concur.you have 28# inj. on the 98s.its enough even on a 150shot.just make sure you swap fuel pmp. when you squezze the 150 or else your rolling the dice.think safety first.
Old 02-08-2004, 11:52 PM
Restricted User
CAT3's Avatar
Funny how our cars are designed:
over 125hp you replace the fuel pump.
spray thru shifts, lets replace auto trans; spray off the line M6 replace rearend
over 200 lets replace stock bottom
spray or not to spray? I say the bigger the better.
Old 02-09-2004, 12:31 AM
35th SS's Avatar
couldnt agree with you more catman.what happen fri.night. the o3 snake was there at the track but had the street tires.thought you guys had a grudge match.didnt wanna run against the faked ss cause had the 28in.slicks I guess not fair huh!
Quick Reply: If you run a wet kit do you need to upgrade injectors?
