Clutch fork broke
Clutch fork broke
Hy guys,
Did this ever happen to you guys, Was driving today when I felt the clutch pedal kinda sloppy, 2 blocks from my house, e the pedal became rock hard, i was in 1st gear and tried driving home. I had to stop at a crossing to let other cars go by, the car stalled. I tried pushing the pedal in twice to start the car (instead of pressing the **** by the pedal with my hand, stupid me) on the second try i heard a weard noice, and the pedal went flet, i started the car and thought is was the slave that went south. After being towed home by a neighbour, I removed the slave to found out my ford broke in 2.
Question, can I weld it (reinforce it on left + right side with a small strip iron) if I cant get a new one?
i could not believe it neither, and I heard of guy with 500hp still using the same fork, i still cant find out how, it got loose. anyway, i will weld it untill I get a new one, my slave(iron) is still intact I will bench bleed it and install it again.
