Fuel Filter For AN Lines
I'm rerouting my fuel lines next week up into the top of the trans tunnel so I don't have them cut again by some punk *** little fu(ker again.
I'm getting summit black push to connect hose and black fittings, running -6 for the fuel and return, but I can't decide on a fuel filter. I don't have alot of room so I was thinking something like this TRICKFLOW FILTER but will that be enough? Should I run 2 of them, or should I look into something else?
I'm wanting to make an order soon, so help a guy out
Thanks in advance
Thanks in advance
I figured I'd be ok, but just wanted to be sure. And when my new motor is built I'll be going to -8 pressure side and leaving the -6 for the return. I'll also be upgrading my fuel pump to a 255 pump since my stocker has 125k miles on it and I would feel beter with a new pump in there
I'm shooting for 540ish rwhp with the new build so I hope so, right now I'm around 400 rwhp so I think -6 is fine considering its bigger than the factory lines its been running on for 3 years haha
I guess I could run them above my SFCs, but I think I'm sticking to my original plan
