BMR Tech2
12-28-2010, 03:23 PM
BMR Suspension
Level 1 Handling Package for 2010 Camaro
Improve overall handling in your 2010 Camaro with a Level 1 Handling Performance Package from BMR Suspension. This kit consists of BMR Sway Bar Kit (SB030 (http://www.bmrsuspension.com/index.cfm?page=products&vehicleid=17&maincatid=77&catid=225&productid=472)) and BMR 1” Lowering Spring Kit (SP019 (http://www.bmrsuspension.com/index.cfm?page=products&vehicleid=17&maincatid=77&catid=224&productid=836)). The sway bars are cold formed from lightweight tubular DOM steel and have an outside diameter of 29mm. The sway bars feature 3 adjustment locations and integrated thrust washers to prevent horizontal movement. BMR springs are constructed from high tensile silicone chromium spring wire and come with a lifetime warranty against spring sag. The Level 1 Handling Performance Package (HPP018 (http://www.bmrsuspension.com/index.cfm?page=products&vehicleid=17&maincatid=102&catid=304&productid=853)) will lower the center of gravity, decrease body roll and dramatically increase the cornering capabilities of your 2010 Camaro. All components also sold separately. Sway Bars available in red powdercoat or black hammertone finishes and the springs are available in red powdercoat only. Installation time for the entire kit is 3-4 hours.
http://www.bmrsuspension.com/siteart/products/HPP018_large.jpg
