C5 LT1 Vette Stall fit in F-body
Old 12-28-2010, 05:05 PM
Lawhead's Avatar
Default C5 LT1 Vette Stall fit in F-body
looking into getting a stall and in the Classified found a C5/LT1 4L60E converter
will this work on the F-body Tranny???
https://ls1tech.com/forums/parts-cla...nce-parts.html
Link to it right there
Thanks for the help!
Old 12-28-2010, 05:14 PM
MasterTomos's Avatar
IIRC, I believe the LS1 C5 corvettes and LT1 Fbody stalls are interchangable, however, the LS1 Fbody Stalls and LT1 Fbody stalls are not.
I think it should work.
Old 12-28-2010, 05:17 PM
Lawhead's Avatar
Woah I just looked into it a little and it says the C5 was an LS1 Car I don't get why It would change from F-body to Vette? maybe someone else will chime in here. Figured the 4L60E should have been interchangeable with every model but that would be to easy :/
Old 12-28-2010, 05:30 PM
Lawhead's Avatar
Seller said it came out of his 95 F-body
So my bad on the thread sorry for the waste of space :/
Need this in thinking about showing my face at the new LTx shootout Bracket they got going
Old 12-28-2010, 09:44 PM
lt1-xjs's Avatar
Any converter from '82 - '97 LT1 w/30 spline will work. I'm not aware of any LS1 converter working in the LT1. Save for the Yank SS, it has been tried and proven. Skimping on the converter will be your biggest mistake.
Old 12-28-2010, 10:00 PM
Lawhead's Avatar
I mean just because it isn't yank doesn't mean it can't be a quality converter. Kind of sick of people saying stuff like that. I mean Vig and Yank weren't just the top of the line on day one they were once a custom shop making converters
Old 12-28-2010, 10:56 PM
wysemunky's Avatar
A couple things about cheaper converters is most of the time they just modify a converter from a smaller car to work. This is a problem for a couple reasons 1. the lock up clutch is most of the time much small then stock, and with a heavier, more powerful car they tend to wear out really quick, thus sending lockup clutch particles through your trans. Number 2. converters expand when extreme pressure is applied to them "like in drag racing", and what that does is push your crank into the thrust bearing causing premature wear and sending particles through your engine. I'm not saying the cheaper stalls are bad, but more that they are risky.
Old 12-29-2010, 12:18 AM
Lawhead's Avatar
Well guy spent 800 on it when it was brand new. So not to say its because he paid that much that its a good converter but there are more then just 2 people that make converter that are good at what they do.
Quick Reply: C5 LT1 Vette Stall fit in F-body
