Advanced Engineering Tech - transmissions help?? skip shift
View Full Version : transmissions help?? skip shift
ls1m6nichols
12-29-2010, 07:21 PM
1998 Camaro with T56. I am rebuilding/ upgrading my T56 6 speed. The diagram shows a Skip Shift lever part on the main shifting rod for 1st/2nd and 3rd/4th. I do not remember taking this part off during disassembly. Also, the drawing shows a hole in the shaft for a pin and the shaft does not have a hole at this location. With the drawing I have, one picture shows the skip shift lever between the shifting forks and another picture with the lever behind the shift forks.
I need some help. Could I have lost this part or is there a chance that this current year did not have Skip Shift Lever?
Thank you for your help.
garygnu
12-29-2010, 07:55 PM
wrong section,you should ask in manual tranny.
timothy
01-12-2011, 01:28 AM
I do face same condition what i do was to remove that shaft coz it is too risky while the hole cannot be fixed in the pin.
