Tools & Fabrication - Does thinner wire weld thin metal better?
stoverz28
12-30-2010, 12:23 AM
I have had trouble welding sheet metal on my project car without it burning through and looking like crap. Im using a miller mig welder with .030 wire, would switching to .024 help to keep me from burning through this stuff?
I have it set to what miller recommends but it still burns through unless i go REAL fast...
01ssreda4
12-30-2010, 12:40 AM
Absolutely, welding thin metal with thick wire is close to impossible.
Mr.Nguyen
12-30-2010, 06:00 AM
When welding on thin metal like a 20 gauge or even 22 gauge sheet metal I use a thin wire. I have the welder set on 1 and the wire speed about 35-40. I also use a 75/25 mix at 30psi on a 120v welder. Hope this helps you out OP
stoverz28
12-30-2010, 01:03 PM
thanks for the help guys. Those are the same settings I was at Mr. Nguyen so I guess i try switching to .024 wire.
sjsingle1
12-31-2010, 12:13 AM
some welding machines just dont like welding thin stuff no matter what you do
Mr.Nguyen
12-31-2010, 02:01 AM
Can you please post up pics of the pieces you welded? I would try the tip being a little further away. Or even have a faster travel speed. are you pushing or pulling?
stoverz28
01-02-2011, 01:28 PM
Ill see if i still have it outside but i think i threw it out. I usually pull using a u shaped pattern.
Mr.Nguyen
01-02-2011, 09:33 PM
Pushing will help you keep the heat down because you are aiming forward if that makes any sense to you. When I get to much heat, I would push rather than pull. When the weld is to cold I would pull the puddle so that I can get more heat.
I forgot to mention if you place the work piece on like a large piece of steal and clamp it down to it. Its another trick to keeping the heat down too.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
