any one have an oil leak?
Old 12-30-2010, 08:21 AM
imnmbr1's Avatar
Default any one have an oil leak?
My friends gxp has an oil leak someone up front and center. Anyone ever had this? Too cold here for me to take the effort to go under it yet. I'd said I'd take a look online. Oil pan?
Old 12-30-2010, 08:34 AM
ohyeahjay's Avatar
check the power steering hose as well, there was an issue with them in cold climate areas and there is TSB on it here somewhere. Not saying this is the issue but I can't remember where the power steering line was leaking from.
Old 12-30-2010, 09:04 AM
Ill_Born_ss's Avatar
Check the lines by the upper side of the rad (Tranny&Oil cooler to rad), the leak will drip down onto the lower rad hose and then migrate to the oil pan. Had mine fixed twice, they replaced the lines up top.
Old 12-30-2010, 09:17 AM
imnmbr1's Avatar
Those powersteering lines were replaced. Ill check the others out
Old 12-30-2010, 12:19 PM
LS1 Racing's Avatar
Rear main seal?
Old 12-30-2010, 08:57 PM
mike690003's Avatar
Crank seal...I think theres a TSB out for it.l
Old 12-30-2010, 10:11 PM
Mels SS's Avatar
Oil pan plug.
Quick Reply: any one have an oil leak?
