where did that piece of the piston go?? lol
Old 12-31-2010, 12:56 PM
Fastdriver1992's Avatar
Default where did that piece of the piston go?? lol
for the last 5 months of racing my car i noticed alot of breather smoke that lead me to doing a leak down test and it had 70% loss. then i come to find this when i take it apart. nowww where the F did that piece go lol
Old 12-31-2010, 01:26 PM
Greekey's Avatar
Wow. You cant find it?
Old 12-31-2010, 02:10 PM
nope its no where to be found and left no traces of it ever leaving. everything looks mint lol i got really lucky
Old 12-31-2010, 02:23 PM
SOMbitch's Avatar
Mine disappeared without a trace too...... the dreaded # 7...... Look just to the right of the fracture and there is a slight scratch where it looks like it came in contact with the piston but the head looked fine... Go figure
Attached Thumbnails where did that piece of the piston go?? lol-dscn0182.jpg
Old 12-31-2010, 02:48 PM
yeah wow my friend told me about this dreaded #7 cylinder. mine happend in the number 2
Old 12-31-2010, 03:06 PM
Jimbo'sZO6's Avatar
damned #7 cylinder! Looks identical to what happened to my LS6 a few years back. My guess is that it went right out the exhaust port. On mine I found a slight ding in the combustion chamber near the spark plug hole.
I'm pretty sure that's what happened to yours too.
Jimbo
Old 12-31-2010, 03:17 PM
brian_rs/ss's Avatar
yeah i was going to say you probably got lucky and it got shot out the exhaust port w/o problem. i'm guessing you have a straight through exhaust? if not it's probably still laying in the chambers of your muffler.
Old 12-31-2010, 05:34 PM
yeah i changed my mufflers mid season and i didnt see anything. its just headers to a 1 1/2ft pipe to a hooker maxflow muffler so it didnt have to go far to get out. not a single mark on the head or cylinder wall i'm probably puttin diamonds in it or mahle with a new set of rods and rod bolts before nxt season
Old 12-31-2010, 07:21 PM
garygnu's Avatar
check the valves on that cylinder for a good valve seat seal.
Old 01-01-2011, 04:51 PM
ShevrolayZ28's Avatar
Remove the baffle in the oil pan and you will find the ground up aluminum. It'll still be in there even after draining the oil.
Old 01-02-2011, 06:40 PM
Hawk777th's Avatar
What is the dreaded #7 thing lol?
Old 01-02-2011, 07:53 PM
lexva_58's Avatar
is flycutting responsble for that to happen to ur piston???
Old 01-02-2011, 10:34 PM
i seriously doubt it. i got the motor used for 600$ with bent valves and pushrods. the bolt that hold the cam gear broke so uk the story. so left the bottom end alone put new cam in with high performace valvetrain so idk how many miles were on the motor before i got it. so after 2 seasons and idk like 400 passes this finally happened
Old 01-03-2011, 06:02 PM
lexva_58's Avatar
lol a lot abuse/fun then lol
Old 01-03-2011, 06:18 PM
yeah definitely time to upgrade. ARP, clevite, diamond, porting, cutting and the works! your next race season should be fun
btw i highly doubt fly cutting would have CAUSED that. i think an untouched stocker would have done the same thing. it just so happens that the break took the path of least resistence which was right by the cut.
Old 01-03-2011, 06:34 PM
SOMbitch's Avatar
More often than not it happens on cylinder #7 which is the the ringland that broke on mine......
Old 01-03-2011, 07:27 PM
Smile
oh yes i had a lot of fun with this car and next year will be even better
Old 01-03-2011, 08:36 PM
MYSTIC-1SC's Avatar
Glad it didnt do damage after the piece broke off.
Old 01-03-2011, 09:35 PM
yes thats wats gonna make this rebuild funn
