Pontiac GTO 2004-2006 - 6LE GTO Gauge Overlays
View Full Version : 6LE GTO Gauge Overlays
Sommer86
12-31-2010, 09:24 PM
What do you think? We've had these for over a year now but just decided today to post them up to see if there is any interest for the Goat crew. :chug:
We've sold over 300 sets for Camaro's.... thought we'd let you in on the fun. Oh, and remember, these are FULLY customizable!
Enjoy....
Stock:
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/IMG_2863.jpg
Ours:
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/IMG_2856.jpg
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/IMG_2855.jpg
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/IMG_2859.jpg
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/IMG_2860.jpg
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/IMG_2861.jpg
6LITEREATER
12-31-2010, 10:06 PM
Also, we can make them any color, add any graphic, etc... Just like all of our other overlays ;) Thanks Mike for making me stop procrastinating, lol!
Robofuzz
01-07-2011, 06:41 PM
That does look nice! Post up on GasTiresOil.com about them as well.
1INSANEGTO
01-16-2011, 07:59 PM
price?
6LITEREATER
01-17-2011, 01:29 AM
^^Same as all the others... Base is $149.
Sommer86
01-17-2011, 01:30 AM
Thanks Robo...DONE! :cheers:
GT-OH
01-23-2011, 09:37 AM
How hard is it to change these out? Also is it possible to make a matching set for the JHP GTO gauges (http://www.jhp.com.au/jhpgto/InteriorAccessoriess/JHP05GaugePod-h.jpg
http://www.jhp.com.au/jhpgto/InteriorAccessoriess/LHD-binnical2-h.jpg)
sergo
01-23-2011, 09:41 AM
not bad and would look pretty sweet with my red needles.
6LITEREATER
01-23-2011, 10:48 PM
Not a problem at all... We do it for Auto Meters already.
ellies4
01-24-2011, 12:31 AM
ignition cyclinder stuck
6.0vette
02-13-2011, 05:30 PM
I like them. How bout 7000 rpm redline?
6LITEREATER
02-13-2011, 05:40 PM
^^No problem.
Sommer86
04-05-2011, 01:37 AM
pics fixed!
Sommer86
05-02-2011, 05:02 PM
Here are installed pics and an install write up...
Remove the bezel. (remove the 2 screws at the top, and pull it forward carefully.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/1.jpg
Don't forget to disconnect the fuel door release
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/2.jpg
This shows the 2 screws holding in the speedo and the 2 for the bezel. BECAREFUL not to lose the clips these screw into. You'll need these again.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/3.jpg
Remember, to get to this step you need to remove the 2 bolts at the bottom of the cluster as well.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/4.jpg
This is the wiring harness to the cluster.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/5.jpg
This is the clip that powers the cluster. Push the little tab in, and lift the lever. SUPER easy.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/6.jpg
Here's a better shot: This is the black lever that pulls up. When it pulls, it releases the connector from the cluster.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/7.jpg
These are the gauge trim rings
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/8.jpg
This is how the speedo looks with the stock face removed. (It's all LED's already)
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/9.jpg
This is where the LED's shine. The trim ring is on to give you an idea.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/10.jpg
Sommer86
Here's the backing of the McNord overlays
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/11.jpg
Here the overlay with the backing removed
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/12.jpg
Mounting tab on the bottom right
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/13.jpg
Mounting tab on the bottom left
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/14.jpg
Overlay laid in place
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/15.jpg
With trim ring installed - The trim ring just lays in place. There are no snaps or anything else to hold it.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/16.jpg
The power clip back in
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/17.jpg
These are the clips I mentioned earlier. You need these to put the screws in.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/18.jpg
Test gauges with power on
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/19.jpg
Test with lights.
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/20.jpg
Sommer86
05-02-2011, 05:03 PM
Bezel back installed. Dont forget to re-clip the fuel door button
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/21.jpg
Everything looks perfect!
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/22.jpg
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/23.jpg
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/24.jpg
Sommer86
05-02-2011, 05:59 PM
Here's an install video
http://img.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/th_IMG_5805.jpg (http://smg.photobucket.com/albums/v329/calstud86/6LE%20Parts/6LE%20GTO%20Overlays/?action=view&current=IMG_5805.mp4)
Robofuzz
05-17-2011, 07:46 AM
Nice!!
GreenBlood
05-17-2011, 09:56 AM
very cool
impulsegoat
05-17-2011, 10:57 AM
Looks good but not enough for 149.99:thumbsdow
Z2K_MrJ
05-18-2011, 08:39 AM
That is nice . Any night pictures ??
Sommer86
05-18-2011, 02:09 PM
You know, I never took any, sorry. :bang:
