Will it be ok not to use a trans. dust/shield?
Im running the 200-4R and I have no trans. shield and I was wondering if that was going to be a problem? Whats its purpose besides the converter and flexplate not being exposed? Will the 200-4R shield work on an LS1? I bought one for a TH350 thinking it would work, but nope! If I dont need it, then Im not going to worry about it, but if I do, then I have to make sure that its going to work on an LS1. Thanks.
I dont have one on my TH400 either. It's better to not run one to help keep the tranny cool. Obviously the last thing you want getting up there is a bunch of dirt or sand, so try to keep it off the rock roads. Don't be afraid to give it a spray of water every so often to keep it from getting allot of buildup from the road either. Little spray of Simple Green, let it soak in, then flush it out with water.
