Whats your build/mods for 2011?
wanted to see what everyone is working on/buliding/mods for the new year.
as for me ima do a lq9 swap and maybe some upgrades here & there.
Impala:
-Find low miles short block
-Install Valvetrain package and Oil Pan
-Swap motor in
-Install Mezier EWP
-Buy and install ASP under drive pulley
-Buy and install 58mm TB
-New o2's
-Dyno Tune at HMS
-Slicks and skinnies for LA invasion
-fix all the little things like rattles ect.
Camaro:
-Find set of 17" 10spoke 2002 SS wheels
-Tint windows
-Swap motor in
-Install Mezier EWP
-New o2's
-Dyno Tune at HMS
Camaro:
-Tint windows
5'' mbrp exhaust on my gf LLY duramax diesel maybe a downpipe and maybe a tuner....
my camaro either some ls6 heads or **** it drop that and get a ls9
if i dont sell formy, get a firehawk hood and paint it
All the basic and involved maintenance crap the previous owner neglected, and the stuff that needs attention as I just broke 120k.
Timing chain
Timing cover gasket
Lifters
Pushrods
Rockers with trunion upgrade
Coolant flush
LT1 radiator
New belts
New coolant tubes
New P/S lines
Brake flush
Hawk HPS pads
Steel brake lines
Front hubs
adj. LCAs (poly)
adj. PHB (poly)
AIR check valves
Low mile stock rearend (til 2012 when i can afford a 12bolt)
Full front suspension rebuild
Poly sway bar endlinks/bushings (F&R)
I just did:
23k stock trans w/ converter
Poly motor mounts
Poly T/A mount
255 fuel pump
Lid
SLP 2OTL catback
It's gonna be a busy year
Timing chain
Timing cover gasket
Lifters
Pushrods
Coolant flush
LT1 radiator
New belts
New coolant tubes
New P/S lines
Brake flush
Hawk HPS pads
Steel brake lines
Front hubs
adj. LCAs (poly)
adj. PHB (poly)
AIR check valves
I just did:
Poly motor mounts
Poly T/A mount
255 fuel pump
Lid
SLP 2OTL catback
