98 Harness VSS Question... Help!!!!
Old 01-02-2011, 10:47 AM
jkade72's Avatar
Default 98 Harness VSS Question... Help!!!!
Can I cut the plug off the factory vss and extend the wires to my 91 suburban vss and plug? Anyone??? The suburban is a 2 wire setup as well.
Old 01-02-2011, 09:53 PM
jkade72's Avatar
Anyone?????
Old 01-02-2011, 10:43 PM
Pocket's Avatar
Assuming 4L60E to 4L60E
If thats the case then yes you can. Make sure by popping the VSS out of the 91 trans and see if its a gear drive or hall effect reluctor. If its a 4L60E, it should be the reluctor and plug in directly, no need to switch connectors
4x4 versions use an adapter/extension harness using the same connector. These are common on S10's in JYs
Old 01-03-2011, 08:04 AM
jkade72's Avatar
The tcase came from a 91 sub with the 700r4 and it is a reluctor. My trans is a th400 with the np 241 behind it. The plug is diffrent but is still a 2 wire hook up. The new plug has a green and purple and the ls plug is yellow and purple. So I should be good to go with splicing in the np241 connector?
Thanks!!!
Old 01-03-2011, 08:50 AM
Pocket's Avatar
Use the adapter or cut and splice
If you do cut and splice be aware the colors switched
http://www.lt1swap.com/pictures/12_b..._radio_vss.gif
Lt grn/Blk: Low
Ppl/Wht: High
http://www.lt1swap.com/pictures/100_1780.jpg
Ppl: Low
Yel: High
Old 01-03-2011, 09:16 AM
jkade72's Avatar
Lt grn/Blk: Low
Ppl/Wht: High
Ppl: Low
Yel: High
You da man Thank you sir!!!
Quick Reply: 98 Harness VSS Question... Help!!!!
