Adjusting stock rocker arms...?
Old 01-02-2011, 11:05 PM
SpeedFreak123's Avatar
Default Adjusting stock rocker arms...?
Can some one tell me how to adjust the stock rocker arms?
I need some help.
Thanks in advance,
Kyle
Old 01-02-2011, 11:06 PM
RamAir95TA's Avatar
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old 01-02-2011, 11:24 PM
Originally Posted by RamAir95TA
Thankyou. Very helpful link.
Old 01-03-2011, 12:14 AM
SexyTransAm's Avatar
this is the way i do it
Exhaust opening/Intake closing
When the exhaust just starts to open, adjust the lash on that cylinder's intake valve then turn over the engine until that intake valve has opened and almost closed then you adjust the lash on that cylinder's exhaust valve.
Old 01-03-2011, 01:12 AM
Village Troll
SS RRR's Avatar
... EOIC ...
Old 01-03-2011, 10:14 PM
great421's Avatar
Default 2x Vote.
Yep - I used that info and used the "spin the push rod" method, then tightened the rocker arm nuts 4.5 flats / three quarters of a revolution. Used red loctite on the Allen nuts - no problems.
Old 01-03-2011, 11:12 PM
im hoping it fixes my problem!!!!!
Old 01-04-2011, 11:00 AM
AChotrod's Avatar
I always use Comp Cams method look at 7-8
http://www.compcams.com/Instructions/Files/151.pdf
Quick Reply: Adjusting stock rocker arms...?
