LT1 intake manifold question
Old 01-03-2011, 12:53 PM
BL96TA's Avatar
Default LT1 intake manifold question
Is there any differance between a 1994 intake and a 1996? Headed back to the junkyard to pick up a few things in a few minutes and wanted to know if the intakes were the same, if so ill pick up the 1994 intake.
Old 01-03-2011, 12:59 PM
RamAir95TA's Avatar
Nope, they are the same. The only differences lie in the 93 intakes which do not have the front fuel crossover provision.
Old 01-03-2011, 01:19 PM
BL96TA's Avatar
Great! Thanks for the reply and your help
Old 01-03-2011, 01:33 PM
quik95lt1's Avatar
dude u are a font of endless knowledge when it comes to OEM stuff on these cars lol....im impressed lol
Old 01-03-2011, 01:44 PM
RamAir95TA's Avatar
Blahhhhh...when you have a job that pays you to surf the internet, what do you expect?
Old 01-03-2011, 02:09 PM
happysem's Avatar
I thought some were port matched to the heads?
Like some have near perfect rectangles, others taper inwards towards the top?
Old 01-03-2011, 02:31 PM
Puck's Avatar
Just like heads, the manifolds can have small differences in the ports between years. I also remember reading about some flowing slightly better and more optimally shaped ports then others.
Nothing I would bother with or worry about though, they are in in essence the same - except for the 93's as Ramair mentioned .
Old 01-03-2011, 02:32 PM
RamAir95TA's Avatar
Yes, they did have different casting numbers, but the port differences are so small it doesn't really matter.
Old 01-03-2011, 02:36 PM
*02WS6TURK*'s Avatar
I've got a low milage intake off my old 94 z28 I'd be willing to part with and sell you at a good price.
Old 01-03-2011, 04:22 PM
BL96TA's Avatar
So how about this then, I got the intake and now im looking at all the crud built up inside. Is there a way to treat the intake to clean all the carbon/crud build up inside of it?
Old 01-03-2011, 04:42 PM
Mine is crud free Got your PM...no worries and your welcome for the offer.
Old 01-03-2011, 05:11 PM
hitmanws6's Avatar
Find a local radiator shop and see if they can hot tank it for you
Old 01-03-2011, 05:29 PM
BL96TA's Avatar
You know what, thats just my luck to. I didn't get your pm until after i had already come back from pulling it.
Thanks for the hot tank tip. Ill search around.
Old 01-03-2011, 05:32 PM
BL96TA's Avatar
One more question, is there a shop that is known for porting LT1 intakes? Id like to get this ported and powdercoated so when i pull my stock intake to fix the oil leak i can replace it with this one.
Old 01-03-2011, 05:34 PM
RamAir95TA's Avatar
There isn't much benefit in porting the stock intake, unless you're putting on a 58mm throttle body, and in that case you can port the manifold yourself with a Dremel.
Old 01-03-2011, 05:45 PM
96capricemgr's Avatar
The rectangular ones are actually bigger than the head port the tapered ones actually match better and are preferred by "as cast" racers.
Old 01-03-2011, 05:47 PM
BL96TA's Avatar
Ok cool, i didn't know. So the only porting other then the TB bores would be if one was to port match there heads then right?
