Valve cover spacers/covers ?
Old 01-03-2011, 04:49 PM
crossbreed383's Avatar
Default Valve cover spacers/covers ?
So, im in need of some valve cover spacers to clear my shaft rockers.
id rwally like to retain a stock type cover for my coil mounts
Ive searched the site, but cannot find any info on anyone using any, or on what results they got?
Also,are any of the different year factory valve covers any taller in different years than any others per se?
Ill be removing all baffling internally,so im only interested in overall height from sealing area to top of covers
thanks
Old 01-03-2011, 05:42 PM
bluehawk2's Avatar
what brand rocker are you running?
Old 01-04-2011, 08:26 AM
So noone has ever ran spacers on there car?
Old 01-05-2011, 08:42 PM
S10xGN's Avatar
Spacers are ~ $150 a pair, with twice the chances for leaks. You can find polished, tigged sheetmetal valve covers (with or without coil mounts) complete on E-Bay for less that that.
Old 01-05-2011, 09:18 PM
but do these budget valve covers seal well at all?
Old 01-05-2011, 09:31 PM
wstaab's Avatar
Make sure you use billet spacers that use OEM valve cover gaskets. They work fine and do not leak. Available in 3/8, 1/2, 3/4, and 1 inch heights. They come with longer mounting bolts.
These are 3/4 inch to clear 1.8 roller rockers with stock LS valve covers.
Old 01-06-2011, 08:59 PM
S10xGN's Avatar
The two E-Bay sets I have seal perfectly, one was from a vendor here (Aaron's) and the other was from "southbayglobal". Aaron's worked with me on custom height covers, the other (much cheaper) outfits sell prebuilt covers in different heights, you'll need to bid accordingly.
Old 01-09-2011, 12:10 AM
racecar's Avatar
I bought a set of 1/2" spacers from Summit, and the worked great for a few years. Then after a teardown, I cleaned the small silicone O ring gaskets with lacquer thinner.
That screwed them up and they have leaked since then. I replaced the O ring with neoprene rubber, still leaked. I bought different rockers, and switched back to stock valve covers.
Old 01-11-2011, 08:10 PM
Mez
Mez's Avatar
Yella Terra sells a thicker valve cover gasket if you only need about 1/8 inch.
Quick Reply: Valve cover spacers/covers ?
