Cam Reccomendations
Old 01-03-2011, 08:42 PM
Blackhawk777's Avatar
Default Cam Reccomendations
I have a set of stock 243's laying around and it's about time for a cam swap. What would net me the best power for a daily driven car. It's an A4, more than likely 3200 stall with 3.73 gears. I am NOT however looking for monster cams (ms4.... things of that nature)
Old 01-03-2011, 08:48 PM
Darkman's Avatar
Do you have long tube headers?
Old 01-03-2011, 08:49 PM
Soon to have BBK ceramic coated ones yes
Old 01-03-2011, 09:30 PM
massconfusion's Avatar
betcha you could search the forum for a thread with a ton of info on this subject....
Old 01-03-2011, 09:34 PM
garygnu's Avatar
the EPS cams makes good power with a little less duration then most cams,a newer better lobe design.get a ls6 intake and #32 injectors .
Old 01-03-2011, 09:48 PM
Don't have time to read the 50 thousand threads on that...... ANYWAYS...... I've heard about the eps lobes. I might have to check them out in a little more detail.
Old 01-04-2011, 04:12 PM
SNLPerformance's Avatar
Feel free to call the shop at 817-750-2000 and we can discuss different options based on your goals, Chris
Old 01-04-2011, 06:26 PM
janaka's Avatar
Check it out.
http://www.guerragroup.com/camshaft_help.htm
Old 01-04-2011, 08:16 PM
TXZ28LS1's Avatar
I have an old X1 cam, 230/227, vigilante 3200, all boltons and 3.73 gears and made 395rwhp stock heads on an auto. I also am looking at adding heads and a ported fast intake.
Old 01-04-2011, 11:10 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You should talk to Squirts11 about his setup. 243's in an auto with and EPS 'lobed cam.
Old 01-04-2011, 11:13 PM
01ssreda4's Avatar
Cam Motion 228/232 cam. .59x lift or .61x lift version.
