VATS???? Cranks then dies
I tried to crank my LQ9 tonight and it fired up on the first try, ran for about a second or 2 and died.... cranked right back up and died again and again and again. Wait 4 me tuned my computer and he forgot to turn the vats off on the last one he did for us. Does it sound like vats to you? No throttle response or anything.
Wait 4 me: aptly named it might appear .
I called him and he said he turned the VATS off, that is what he said about the last one. On the last one we pulled the pcm from another car and it fired right up. I wish I had access to another pcm so I could try it. I think I am just gonna see if I can get Gomer to come down and do it right!!!
I'm reading lately that if there are codes remaining in the ECM while VATS is in process of being disabled, that the VATS disable will not 'take'.
I've also seen where, depending upon the system used to disable VATS (EFI Live??, Hypertech??, etc), that though VATS appears to be disabled, that it's NOT disabled.
Confucius say..."those who do not REALLY disable VATS get 10 whacks with a wet fanbelt, and should offer their tune for 1/2 price!"
Well............... it wasn't Jesse's fault. It was the idle air sensor, replaced that and it cranked up and ran fine. Damn speedo still won't work though, but everything else including the windstar fans work like a charm. I got to get a new thermostat because the computer is telling the fans to come on before the thermostat opens.
