2000 ws6 headlight issues!! the usual fixes wont work!
I recently bought my first f-body a 2000 ws6 t/a. Since I had it the headlights have not worked properly. At first I thought that (re)connecting the wiring harness to the motors and replacing the gears would fix it. Tried that same thing. Replaced the headlight module TWICE! Didn't help then one side would go up and not the other checked all connections and they are good fuses are good too. Replaced drl module and still the same except now on low beam all.four lights come on with a brownish glow they're not burned out though I checked. Then on high beam one side (same side that goes up and down) will work correctly. Now I've pulled the bcm out to check it out. Can someone please help??!! Im going insane thanks in advance!
Save the manuals!
Mine were working fine until I unplugged them to do a gear swap - and then this stuff started happening. I had to take the male terminals out of the connector body and polish them with steel wool and also had to replace some female terminals that were too far gone. Once I cleaned them up - all has been perfect.
That may be but if both circuits are good going into the motor. Wouldn't it mean that it's not receiving power from the source? It could be ground but it could also be that its not getting the correct signal. Then the bcm is too blame because all the other modules are good.
Save the manuals!
Ungrounded Moderator
Normally when you have multiple bulbs that illuminate improperly (tail lights, head lights, or whatever) it is because of a bad ground. What happens is that the power to one bulb ends up grounding through the other so both illuminate rather dimly.
The headlight doors and the headlight bulbs are also completely separate except that they are controlled by the same switch. However, the headlamp door control module shares a ground point with the left headlights so that's the first place I'd look.
You can forget about the BCM - it has nothing to do with the headlights in any way.
Save the manuals!
Its only one side that's jacked up, right? If so, I'll be the problem is in the headlight door motor connector. (All the door motor wires and bulb wires go through that connection.) Got to unplug it and check it out. You can test the ground continuity at that point, etc.
Save the manuals!
Yea... that's ugly. I had one like that and was able to remove the terminals from the connector body and polish them up a bit. Getting the corrosion off the plastic may require a bath in something. If you are adventurous and want to rebuild the connectors, crimp on new terminals, etc. I can assist with part number references.
