5.3 Pilot Bearing Hole
Old 01-04-2011, 10:48 PM
JAC
JAC's Avatar
Default 5.3 Pilot Bearing Hole
I was told that all 5.3 engines cannot accept a pilot bearing for a standard shift. Automatic only unless you bore the crank.
Can anybody clarify this for me?
Thanks
Old 01-04-2011, 11:53 PM
garys 68's Avatar
I just tapped an LS7 pilot bearing into the outer bore on a L59 the other day.
Old 01-05-2011, 12:31 AM
bagged67camaro's Avatar
u can run manual trans on the 5.3 im running a t56 on mine just gotta install the ls1 pilot bearing into the crank
Old 01-05-2011, 11:55 PM
JAC
JAC's Avatar
Smile Clarification
Thanks
Old 01-06-2011, 10:11 AM
STEEPSS's Avatar
Its a truck motor, NO WAY can you ever put a manual behind it. Or even go fast for that matter.
Quick Reply: 5.3 Pilot Bearing Hole
