Carbureted LSX forum - MAP sensor part number - what are you running?
speedtigger
01-05-2011, 12:59 PM
I need a part number to order a map sensor. What is the best one to run, where did you get yours?
Pop N Wood
01-05-2011, 03:49 PM
Pulled one off a generic GM motor in the JY. Took a picture of the MSD connector just to make sure it would plug in. The sensor doesn't have to be off a V8, they are all the same.
It will be hard to beat the $5 JY price. You can probably get it for free if you just throw it in the bottom of your tool box when getting something else.
S10xGN
01-05-2011, 08:00 PM
AMEN! I bought one new at Advance and paid $55.00! Any one-bar GM MAP from mid-nineties up should work. Just look for the same connector shell, you should be able to adapt the pressure end to your manifold.
rojs234
01-06-2011, 10:46 AM
No question you can find one at the JY, but check the MSD connector first, like said above. I bought one at O'Reilly when I first set mine up....looked the same, but the little tit inside that assures you put it together correctly was on the opposite side! I had even specified one for an LS1. Don't know if it was boxed wrong or what. Wound up like above with a used one.
Luke Skyjacker
01-08-2011, 08:54 PM
can i see a picture of how you guys mount these?
S10xGN
01-08-2011, 09:16 PM
Look right under the air cleaner, it's plugged into a rubber 90° fitting that's plugged into a homemade hose barb fitting:
http://www.ls1tech.com/forums/attachments/generation-iii-internal-engine/206468d1258593506-autometer-oil-pressure-sender-100_0849s.jpg
Luke Skyjacker
01-08-2011, 09:30 PM
thanks.
speedtigger
01-09-2011, 12:52 PM
Sooooo. Anyone have a part number for what they used?
S10xGN
01-09-2011, 07:50 PM
My box says BWD / V08235 / EC1686 on it, but again, that's a $55 part from Advance...
speedtigger
01-09-2011, 07:53 PM
Thanx Russ. That is a great looking Maverick. What does it run at the track?
S10xGN
01-09-2011, 08:29 PM
Haven't run it yet (I have a G-Tech Pro, but...) I'm still sorting out a few bugs. RWHP should be around 375 or so, weight should be around 2900 with me in it. Those numbers (in a perfect world!) show 10.92 @ 122!
Where in FL are you? I have a sis in Cape Coral and Dad in Ft. Myers. We'll be heading there in June...
speedtigger
01-10-2011, 08:00 AM
Tampa Bay area. It is about 2 1/2 hours north of Ft. Myers.
Prorac1
01-10-2011, 10:12 AM
http://cgi.ebay.com/ebaymotors/BRAND-NEW-SU1176-Manifold-Absolute-Pressure-Sensor-MAP-_W0QQcmdZViewItemQQitemZ300494379944QQptZMotorsQ5f CarQ5fTruckQ5fPartsQ5fAccessories#vi-ilComp
I interchanged the part number (EC1686) and it came up as SU1176 (autozone), and I stumbled upon this ebay link with a list of compatiable vehicals. Looks like an easy JY find. Hope this helps, Eric L
speedtigger
01-10-2011, 11:01 AM
I had a look at that MAP but I could not see inside the end of the plug connection to see if it looks like a match.
Prorac1
01-10-2011, 11:04 AM
Its a match. It sounds as if almost any late model GM will work. Even some hondas, etc. Eric L
speedtigger
01-10-2011, 11:15 AM
Thanx Eric!
speedtigger
01-10-2011, 11:28 AM
What do you think of this one? Nice price. Small and compact and appears to be a GM part:
http://cgi.ebay.com/ebaymotors/BUICK-OLDSMOBILE-ISUZU-MAP-Sensor-ALL-GM-CARS-16249939-/220717485218?pt=Motors_Car_Truck_Parts_Accessories&hash=item3363c98ca2#ht_31888wt_1165
rojs234
01-10-2011, 11:33 AM
Here's the one I used. If you can't read it when you click on it, here's the number. It's a Delco # 16212460
62261
USA
schary
04-20-2011, 07:37 PM
so most of you guys are putting the map in the rear manifold hole? could be a stupid question where are you plugging the brake booster vacuum hookup to? and is there a map sensor adapter to adapt to the threaded hole on the GM intake? thx
:headbang:
Pop N Wood
04-21-2011, 06:23 AM
I connected mine to my Holley's unported vacuum line. I connected the brake booster/PCV line to the carb's also. The GMPP manifold doesn't have any vac connections.
speedtigger
04-21-2011, 08:25 AM
:headbang:
Time to drill and tap a few vacuum holes.
