Ls3 pcm
LS1Tech Sponsor
Vehicle Speed Sensor... used for your speedo, and can also be used by ABS and stability control systems...
the pulses per mile would depend on the cars gearing and tire size...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Thanks ssgunny and 06MonteSS for the reply. I should have explained a little more, I was looking for what effect the VSS signal has on the engine management system. I am using a 6 speed manual transmission (F40) that puts out 60K pulses per mile. But when I am running at 60 MPH the scanner tells me the PCM has a reading of a little over 30 MPH. Does this effect engine performance. The speedometer is corrected to the correct signal with the use of a Dakota Digital frequency converter for 60K to 4K pulses per mile.
