stock injectors with lower fuel pressure?
I'm doing a 5.3 swap into my 350Z and I need some help on what injectors to run. I'm was planing on running the stock 350Z fuel set up, already have a Walbro 255 pump in there. The stock 350 fuel set up is no return and runs at 51psi not 58 like the ls1.
Do ya'll think I will be ok with stock 28lb injectors, with my lower fuel pressure that would make them 26.3lb injectors ( going by this http://www.deatschwerks.com/catalog/...alculators.php ).
Its just going to be a bolt-on 5.3 so no huge power, may put a Z06 cam in later but that would be it.
