Paint & Body Work - what can i use to fill the holes in my engine bay?
99 Blue Bird
01-06-2011, 10:37 AM
my motor is out of my car and i am wanting to do the WIRE mod. what can i use to just fill in the couple holes on the fender wells? a metal epoxy? bondo body filler? i dont have access to using a welder and filling the holes that way so im not sure what else will work. help me out guys.
Anniversary "Z"
01-06-2011, 10:41 AM
Stickers :thumb: :lol:
Subscribing for answers!
toplessHO
01-06-2011, 05:57 PM
a good 2K seam sealer
best to dimple on the finished side.
Would work even better if some type of re enforcement
such as stainless screen is on the backside and sealer is pushed thru it.Welding is really the best way.
Bondo will fall out
Swiat34
01-06-2011, 08:32 PM
Without welding, I say dimple the visible side and use JBputty to cover the dimpled area and also some on the underside spreading the putty around the hole. When it's dry, sand the visible side flush, prime and repaint. The goal to applying a putty is to sandwich the metal around the hole and not fill just the hole. If the hole can be seen on either side after applying the putty, it could fall/vibrate out. Someone you know has GOT to have a welder tho.. Local Tech school maybe??
if you can get to the backside of the holes you wanna fill, take a piece of metal bigger than the hole obviously, and apply "Nortons- Speed Grip" press to the hole and smooth out on the shown side with a spreader.
note: adhears to bare metal the best, so grind the little piece of metal on one side and around the hole both sides.
when after its cured you can sand and prime. ALSO note you can put filler over it ONLY with the speed-grip primed with no speed grip showing
absynth408
01-07-2011, 02:23 AM
go to home depot and get a wall patch. its a nice thin screen or solid piece depending on brand cover it and sand..easy as that
99 Blue Bird
01-07-2011, 04:37 PM
that is a good idea. have you done this?
99 Blue Bird
01-07-2011, 04:40 PM
yea i know somebody with a welder. i was just mainly trying to avoid welding so that i didnt have to grind down the welds. i was just lookin to fill the easiest way that actually works and than sand it down and paint it. but maybe i should just weld them shut and stop being lazy before i might end up regretting half assing it.
Swiat34
01-08-2011, 10:32 AM
It's gonna be just as much work filling and sanding with a putty. I honestly believe you'd be better off doing it right the first time here since the work won't be THAT much worse.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
