Whats the biggest shot I can run with NX wet kit single nossle...150 or 200?
I was told with the single nossle it would max out at 150-175
and I found out theres a 200 shot for this single nossle
heres the n20 jets for a 175 and 200 and would like to know if anyone has ran a 200 shot with this kit?
N20 Fuel
73 38 175 Shot
78 41 200 Shot
If not does NX make a bigger nossle for 200-250 shots?
N20 Fuel
73 38 175 Shot
78 41 200 Shot
vette=lack of penis
N20 Fuel
73 38 175 Shot
78 41 200 Shot
N20 Fuel
73 38 175 Shot
78 41 200 Shot
The kit maxes out at 150hp with all of the factory pieces. From what I understand the only thing that you have to replace is the -3an from the N2O solenoid to the Nozzle. You have to upgrade it to a -4an line. This will allow you to be able to utilize the kit for a larger shot. Hope this helps.
Your incorrect.
Kit maxes out @ approx 220 rwhp (from lots of testing).
The main limitations on a standard NX wet kit weve found is the 4an line and nitrous solenoid. Weve made 300 rwhp through the 3AN that were 1-2 ft long. Standard nozzle will flow 300 rwhp techinically.
Nitrous Express also makes a SHO kit that will flow 400 rwhp
if all you want is 200 hp single, then you need to -4 to replace the -2 line that goes from solenoid to nozzle. I have the MAF kit and NX told me this is what i would hae to do, and that the -4 will easily suppor 300 hp shot (-4 main line). I had anter wet kit on a vette that used a single nozzle and I used the SHO purple nozzle that would support 400 hp single shot.
Ok so I might just go with a -4 and bigger nossle to make it easy and I would later be able to spray as much as a 300 shot right?
Do I have to replace the fuel line that connects to my nossle also? Since its the same size as my n20 line.
I have heard that you shouldnt spray more then a 250-275 shot throught the intake, have any of you had any problems spraying this much through the intake with these nossle kits?
well i've seen over 250 RWHP through a single nozzle w/ a -6 line and big noid and 73/41 jetting (fat i know) but thats only 175 jetting. plenty of room to grow. ;D whats limiting you to one nozzle? class regulations or just curiosity?
