Who grinds FTI (Ed Curtis) cams?
Old 01-06-2011, 03:59 PM
Rise of the Phoenix's Avatar
Default Who grinds FTI (Ed Curtis) cams?
Are these your regular comp lobes or does Ed Curtis have his own special lobes. Just wondering because his cams are quite pricey and would like to know what makes them so special.
Old 01-06-2011, 04:08 PM
PREDATOR-Z's Avatar
IIRC it is Compcams, some on proprietary lobes, depends for which type motors.
What is special is that Ed has years of experience and proven grinds. His kits are well put together and are matching perfectly.
Old 01-06-2011, 05:16 PM
hirdlej's Avatar
Yes, Comp Cams grinds his camshafts.
Old 01-06-2011, 06:59 PM
commy's Avatar
They work.
Old 01-06-2011, 07:00 PM
vettenuts's Avatar
There are also a number of cams out there, sold by other vendors, that are his design.
Old 01-06-2011, 10:31 PM
studderin's Avatar
anyone that can get done what he needs. he uses more then comp.
Old 01-06-2011, 10:46 PM
GTO1_OHIO's Avatar
The cam he just speced for me this week he said has Lunati lobes ... interesting that Comp would be grinding it for them.
Old 01-07-2011, 09:55 AM
miami993c297's Avatar
Are Ed Curtis "lobes" more beautiful than others???
Christian
Old 01-07-2011, 10:03 AM
Christian
That's what I'm wondering too. Does he have his own specific lobe design, like EPS has their own lobes, Futral has his own lobes, etc; and to be more specific for LS engines.
What would be the benefit of having Ed grind my 230/234 110 lsa cam over say, Comp?
Old 01-07-2011, 10:05 AM
LSX Mechanic
Damian's Avatar
Ed specs his own lobes, and uses Comp to cut them.
Old 01-07-2011, 03:44 PM
So does Comp Cams have lobes that only Ed speced cams can get?
Old 01-07-2011, 04:10 PM
BaddBird's Avatar
Why dont you ask Ed?
Old 01-07-2011, 04:26 PM
edcurtisFTI@verizon.net ...for the Man.
Christian
Old 01-07-2011, 04:42 PM
LSX Mechanic
Damian's Avatar
You're not understanding.
They are not "Comp" lobes. It's a proprietary lobe designed by an outside source that uses Comp as the manufacturer to cut them.
Old 01-07-2011, 04:51 PM
01ssreda4's Avatar
Thats what he was asking so obviously the answer is yes.
Quick Reply: Who grinds FTI (Ed Curtis) cams?
