what parts do you need to convert a 5177 to a wet kit?
Old 02-09-2004, 12:07 PM
smokinHawk's Avatar
Default what parts do you need to convert a 5177 to a wet kit?
Helping a freind of mine do an install on his 98 camaro.
He has a cam, lid and longtubes/loudmouth
starting to think he doesnt have enough injector (or pump) for a good size shot.
think he'll be around 380rwhp, so i told him he might want to only go with a 75 or 50
he would like to be running a 100 shot, so i told him he might want to go wet.
what parts do you need to convert the 5177 to a wet kit
and how much does it cost.
also how much can you get out of the 98 injectors?
Old 02-10-2004, 09:20 AM
rubber duck's Avatar
NX actually makes a wet kit conversion. It includes a fuel solenoid, a line to go from the shrader valve to the solenoid and from the solenoid to the nozzle, a new nozzle(you'll need one), and jets. I think they sell it for $245.
Old 02-10-2004, 09:21 PM
JuicedSS262's Avatar
TNT aslo sells a nice conversion kit.
I have it, and after using it for quite some time, I combined it with the NOS 5177 to make a very lethal dual stage. Making well over 600 rwhp the only fuel system change is a Walboro intank pump.
TNT states that if you use their kit with more than the 100 shot, to upgrade your fuel pump, but the injectors are more than enough.
Old 02-11-2004, 06:35 AM
smokinHawk's Avatar
thanks
any info for how much the 98 injectors can take?
Old 02-12-2004, 05:18 AM
Originally Posted by smokinHawk
thanks
correct me if i am wrong, but the 98 injectors were bigger than all the rest. I pushed my 2000 injectors to apx 650 rwhp and 700 rwtq. Way beyound what should be done, but if you stay in the 500/500 range you are more than safe.
Old 02-13-2004, 11:38 AM
smokinHawk's Avatar
ive never hear that much?
are talking with a wet shot or just on a dry shot??
Old 02-13-2004, 06:21 PM
415 rwhp NA, TEA heads. TR cam
2 stage's
125 dry shot
150 wet shot
stock injectors, stock bottom end.
Old 03-08-2004, 09:42 PM
BB
BB's Avatar
0031nos is a conversion kit that will be released shortly. Otherwise you
will have to order these part numbers.
13716-SNOS SOFT PLUME NOZZLE 1
15060-2-SNOS 3AN X 2FT. HOSE TO (RED) 1
15060-1-SNOS 3AN X 2FT. HOSE TO (BLUE_ 1
15231-SNOS 4AN X 2FT. HOSE (RED) 1
15571-SNOS FUEL FILTER 1
16050-SNOS FUEL SOLENOID 1
17945-SNOS 1/16"NPT X 4AN FITTING 1
15990-SNOS 1/16 NPT TAP 1
19R904 HOSE BARB FITTING 1
36R646A 5/16" CLAMPS 2
16500-SNOS SOLENOID MOUNTING BRACKET 1
Old 03-10-2004, 01:18 PM
4thGENRETARD's Avatar
Good info BB i've been contemplating to switch to wet, when do you think that kit will come out?
Old 03-10-2004, 03:46 PM
BB
BB's Avatar
NOS wouldn't give me a date. They just said soon.
