would you???
Old 01-06-2011, 08:17 PM
waybad's Avatar
Default would you???
would you run a lift of .612 on pac springs that were good for .600?
thanks TC
Old 01-06-2011, 08:35 PM
Darkman's Avatar
Which PAC springs?
Old 01-06-2011, 10:13 PM
crainholio's Avatar
Only if I really hated my engine.
Old 01-06-2011, 10:19 PM
NVR_SPDS's Avatar
If your looking for a very good reason to replace your engine, then SURE!!!
Heres what happened to me when a spring failed: https://ls1tech.com/forums/generatio...l#post13804872
Old 01-06-2011, 10:32 PM
supersick99z's Avatar
thanks TC
I think you already know the answer to that....
Old 01-07-2011, 07:06 PM
waybad's Avatar
Thanks,, thought it would be a bad idea,, but a guy locally said it would work,, won't be buying his cam!!!!!!!!!!!!
Old 01-07-2011, 07:24 PM
TurboBuick6's Avatar
Originally Posted by Darkman
Which PAC springs?
Im going to guess 1218's.
You actually can do it but I would not recommend it. The 1218 and 1518 have the same solid height. The reason the 1518's can run 650 compared to the 600 the 1218's can run is because they are nitrided. The nitriding process strengthens the exterior of the wire enabling the spring to compress more without hurting it.
Old 01-07-2011, 07:35 PM
Darkman's Avatar
I agree and I was not about to suggest that the PAC lift specification be exceeded, but I was going to check that lift specification against the PAC Catalog.
Old 01-07-2011, 07:40 PM
Yeah thats what I was quoting you about. .600 lift is the 1218's.
The rest was for general knowledge for everyone.
Old 01-07-2011, 08:14 PM
waybad's Avatar
mine are 1218s
Old 01-08-2011, 01:10 AM
Midnight02's Avatar
Ummm .612 > .600, so...NO, not unless your comfortable with eating the expense of an engine failure instead of just buying the right springs for the job. Typically the springs go for less than the rebuild.
