Cam swap with DOD turned off; retaining DOD lifters?
As it says...I want to know if anyone has done a mild cam swap on a DOD/AFM car and was able to utilize the factory DOD/AFM lifters with the DOD/AFM turned off? I will obviously run springs and probably rods but, just want to know if I need to switch out the DOD/AFM lifters....Ive been told they like high revs surprisingly as a side note....
Problem I have is the im FWD...LS4...so a lot of guys that change cams out in our motor usually change the timing chain and cam bolt from a 1 bolt to a 3 bolt gear and then have to change out the oil pump to the LS6 style due to our pump having too much psi which is intended for the DOD/AFM system when it is operative. Most of them just do away with DOD/AFM all together and do a rough re man due to there not being a "KIT" for the forgotten LS4.....
They will ultimately do as a lot of the G8 guys do and just change the lifters to the LS7 style and replace the above things i listed as far as cam goes and oil pump, and then do a non DOD/AFM valley cover swap and call it a day....
but just to let you know...its a pain in the A&$!!!!!!!!
So, wanting to see if i can just put this cam in with some springs and some pushrods and keep the DOD/AFM off and use the factory DOD/AFM lifters?
Thanks all,
Rossko
Thanks all,
Rossko
I'd just do like everyone else and get rid of the DoD stuff and use the LS6 pump with a cam and aftermarket valley cover. You figure you need to drop the cradle/lift the engine high enough to put the cam in to begin with, so why not do it once and forget it?
