Ls1 Wont start, drove fine yesterday, today cranks but not firing
Old 01-07-2011, 09:49 AM
camarojokester's Avatar
Default Ls1 Wont start, drove fine yesterday, today cranks but not firing
Hi, I went out to drive my car today and all it does is crank. I tested it and Im not getting any spark or pulses, so I changed the crankshaft position sensor hoping that will do the trick and nothing. I checked all my fuses and relays and they turn out fine. It drove fine yesterday and today I have this. Could it be that my Pcm took a dump? Please Help.
Old 01-07-2011, 12:01 PM
no one, I am thinking that maybe its the ECM
Old 01-07-2011, 01:19 PM
1lejohn's Avatar
Yea I would think the PCM or the wires and connector to the crank senser. How about the VATs?
Old 01-07-2011, 01:30 PM
VATS is tuned out. I checked all the grounds. Ill recheck the Crank sensor connector later
Old 01-08-2011, 07:44 AM
Old Geezer's Avatar
Fuses???
Old 01-09-2011, 10:58 AM
NHRA4MULA's Avatar
check the ing relay under the hood switch it with the ac this happend to a friend of mine and the dealer had a hard time finding it
Old 01-09-2011, 11:01 AM
babbage1109's Avatar
Ignition/starter relays. Check em. The fans take the same kind. Just swap them and see what happens. It's happened to me before
Old 01-09-2011, 03:11 PM
robbyredneck's Avatar
do you have fuel pressure?
Old 04-06-2012, 05:52 PM
blackenedss's Avatar
I am having the same exact problem... My ignition relay keeps blowing and I'm not sure why. I narrowed it down to that at least. Also, are the AutoZone brand relays ****?
Should I use OMRONS?
Best,
Julian
Dallas, TX
