TA girdle Q
common compared to a average automobile, yes. for our cars its less common than breaking gears.
gears you can't help. the cover is a good idea in theory, should help make everything but axles live longer. has a drain plug and holds more oil. $150 bucks which may save you $1000 makes sense to me.
good luck, because your still gonna need it.
what ever the reason i lost a bunch of noise when i put mine on. (also stepped it up to thicker diff fluid and the cover holds a lot more oil)
I got it for $20 and some help installing valve springs. I never really hear to much about them so i figured id learn a lil more about em. Im not to worried about the rear cuz once it goes im stepping up to an 8.8. What fluid should i put back in?
I believe the reccomended weight is 80-90, and honestly, any brand will probably work fine. These rear ends will fail from something else before they overheat or are underlubricated due to the fluid choice. I plan on running Royal Purple since it already has the additive in it, while many other brands do not and you need to buy it/add it seperately.
