MN12 vent tube, part number?
I ordered a "transmission vent tube" from gmpartshouse.com and they sent me the steel 90° nipple that presses into the case. I need the black plastic vent tube that strings forward and is retained on a midplate bolt. The the black one in Merv's picture..
Thanks in advance, and if anyone has one laying around, I'll buy it.. Need tube and the white deal in the end, mine got melted when welding the new trans tunnel in.
TJ
TJ
Yep. https://ls1tech.com/forums/13955359-post4.htm
That 14689 and use of a Dorman PCV tube assy will let you make a short one. Nothing wrong with rubber hose either; just have to hold it up w/ the stock bellhousing bolt clip.
