Diagnostic Link Connection Problem!
Old 01-07-2011, 10:01 PM
flatbird's Avatar
Default Diagnostic Link Connection Problem!
When I scan through the OBD2 port it shows error. What would prevent the scan tool from communicating with my ECM/PCM?
Old 01-07-2011, 10:04 PM
msydow's Avatar
fuse?? thats what it was when my programmer wouldnt communicate with my truck.
Old 01-07-2011, 10:50 PM
flatbird's Avatar
Maybe...power/acc? Courtesy?
Old 01-07-2011, 11:15 PM
flatbird's Avatar
Checked the cigarette/accy. It's good...what in the hell could it be?
Old 01-07-2011, 11:28 PM
NewOrleansLT1's Avatar
Some years had ODB2 connectors with ODB1 programming. What year is your car?
Old 01-07-2011, 11:40 PM
flatbird's Avatar
Old 01-08-2011, 12:27 AM
flatbird's Avatar
I wired in a custom manual fan switch a year ago...would that cause interference?
Old 01-08-2011, 09:38 AM
flatbird's Avatar
Anyone...
Old 01-08-2011, 10:38 AM
tricked94camaro's Avatar
what new orleans said. i KNEW you were gonna say 1996
Old 01-08-2011, 10:41 AM
SexyTransAm's Avatar
96 is obd2. so check the wires on the rear of the DLC to make sure they all look right and ya dont have one pulled out. is the reader you are using getting power and just not reading or no power at all?
Old 01-08-2011, 10:52 AM
from what i've heard... the very first few of the 1996 models may have obd I.... not sure if i should believe that though
Old 01-08-2011, 11:14 AM
flatbird's Avatar
I'll check the wiring...the scanner has power it just reads connection error when scanned.
Old 01-08-2011, 11:16 AM
flatbird's Avatar
I thought all 96 and up were obd2, but what do I know. I'll check the wiring...the scanner has power it just reads connection error when scanned.
Old 01-08-2011, 01:29 PM
flatbird's Avatar
All the wiring is intact. There are six wires running to the port, is that correct? If it were an obd1 computer how would I go about identification? Also, my cigarette lighter wasn't hooked up for a few months, so I hooked it back up and unbolted my battery for a few min before scanning. Would that have anything to do with my issue?
Old 01-08-2011, 02:17 PM
flatbird's Avatar
I know for a fact it's obd2...
Quick Reply: Diagnostic Link Connection Problem!
