how can i make my engine run cooler?
i did a few WOT runs in my car the other day using efilive to monitor the o2 readings, and i noticed that after 2 runs, the temp got up to 230 degrees (the temp outside was hot as hell). will running a 180 degree t-stat help? anything else i can do? thanks!
The electric pump pumps less gallons per min. than stock. Evans just came out with a new water pump that flows 20% more than stock. From the sponsor section...
Evans Cooling Systems Inc has just released a new highflow LS1-6 water pump. The billet coolant pump and pulley flows over 20% more than stock and changes the cooling pattern for a more even cooling. The pump increases cooling efficency in modified LS1 Corvettes, Camaro`s and LS1 based motors. Evans has changed the design of the OEM pump casting and includes a billet pulley hub and heavy duty 3/4" shat bearing assembly. It also includes a 3.8" OD 8 vane scrolled impeller to reduce paracitic horsepower loss at high RPM. A new serpentine belt is requiered. We will have these in stock in a couple of days I will get you pics then.
Evans complete water pump with billet pulley $469.95 for Corvettes
Evans complete water pump with billet pulley $469.95 for F-Bodies
Goodyear serpentine belt $49.95 either
Also Evans new NPG R race coolant in stock $25.95 a gallon
Nate
Nate
LS1Tech Administrator
Received 1,486 Likes
Or get the HPP3 or edit to get your fans to turn on sooner.
all you need is the fans to run, low will do alright, high will keep you at 195 or so, all day long.I notice in my car, ac off in traffic will hit 228 with the fans under computer control, my low speed fan switch seems to keep at 195 or so.
slp sells an overpriced fan switch, or you can make you own, like did. Mine has full high/auto/low control, plug and play, and no ses lights. PM for details. the ls1 method works for low, but not high, as you will get a ses lights.
Ryan
Ryan
thanks for all the replies. no i do not have the FTRA (i know it makes the car run a bit hotter since it blocks the radiator). im going to try the fan switch and the 160 t-stat, thanks!
i have the 160 T-stat and programms. ECT's lock in at 185 and stay there, even on the warmer days of winter 60's etc.
The idea of course is to not actually run at 160, but to give the fans the time to cool the coolant. If you ran at 160 you'd seriously decrease the life of your motor. Notice how just about every car on the planet runs at 195-210 for complete combustion of gas? They didn't pull this # out of their azz.
Lower thermostats are general band-aid patches for those who can't afford to get a new radiator that was designed for the level of power output or driving styles that are matched. Everyone knows when you up the power significantly or track it etc you need more cooling system, a t-stat will never accomplish this.
