Camshaft opinions
Old 01-08-2011, 09:22 PM
Car Salesman's Avatar
Default Camshaft opinions
I want your opinions on the camshaft i am thinking of puting into my 95 T/A.
My car is stock Except for cold air intake, air foil, and metal intake bellow.
It is a 6 speed with 342's in the rear
i do not have headers. yet... i have 3inch pipe -manifolds- back (stupid, i know), no cat, 40 series muffler.
The cam i am thinking of choosing is Crane 227: (210/224 .511/.553 112lsa) w/1.6RR's
I am going to call Summit or Comp and have a kit put together with proper springs and roller rockers. I want to know from the expierienced what you thinnk of this cam choice for a stock application. i chose it because of the low shift point, be it my rotating assembly is stock. My fear is that it is to small and it may be a waste of time and money to go so small.
i know our heads are restrictive when i comes to the exhaust side, and this cam seems to compensate well for that. Ive also read that many people hate the LT4 hot cam. This cam is smaller than that, so thats does not sit well with my decision.
Any input will be greatly appriciated, but i do not have alot of money so budget minded segestions would be extra awsome.
Old 01-08-2011, 09:25 PM
LSWHO's Avatar
Great cam, I'd go a bit bigger with a 6 speed though.
Get some headers or your power will be quite limited. Also don't let summit spec a kit for you. Comp will be fine as long as they don't spec a cam for you too.
Old 01-08-2011, 09:29 PM
You don't like comp cams? mind my asking why? i was going to go with them for everything. How much bigger? any numbers in mind?
Old 01-08-2011, 09:57 PM
speed_demon24's Avatar
I wish I never sold that cam. I trapped 115 with it in a full weight car with mildly ported heads. Awesome street cam and a solid performer at the track.
Old 01-08-2011, 10:05 PM
Really wish i had the money for head work...
Old 01-08-2011, 10:21 PM
hitmanws6's Avatar
Give LE or AI a call and see what they recommend
Old 01-09-2011, 11:10 AM
SS MPSTR's Avatar
Great cam choice for your combination.
Old 01-09-2011, 11:45 AM
96capricemgr's Avatar
With a 6 speed you should do 4.10s first.
That is a nice mild cam, with manifolds and good tuning it might even be mistaken for stock.
That said most of us go a lot bigger even with a stock rotating assembly.
Old 01-09-2011, 01:17 PM
Go On 3's Avatar
good cam but make sure u think about ur long term goals u may want to got a little bigger depending on that u want out of it.
i went comp cam 226/230 .568/.583 and love it
Old 01-09-2011, 01:48 PM
LSWHO's Avatar
From what I've seen of their suggested cam specs on a custom grind it's not something I'd try running. Usually quite large and require much better and therefore much more expensive valvetrain and will more than likely make no extra power.
Old 01-09-2011, 03:06 PM
i have 4:10;s waiting in my garage.
Ok i think im going to look for a bit bigger cam, im also going to talk to LE and get there opinion. and after i did some reading on Comp Cams and got mixed opinions on there suggestions and specifications. I guess rpm ranges for Lt1's are never accurate? found that strange, and correct me if im wrong. But Il look into a different provider.
Old 01-10-2011, 12:35 PM
1961ba427's Avatar
Have you looked at the xfi 466?
Old 01-10-2011, 01:22 PM
l 95 Trans Am l's Avatar
I would email Lloyd Elliot, im ordering one of his custom grounds in a few weeks for $300. He can make a cam for anyones needs.
Old 01-10-2011, 03:09 PM
n2oblkz's Avatar
I'm running an AI 226/234 cam in my car with a 6spd and 3.42 gears and it works out really well. I would suggest giving AI a call or if you are wanting to stay with Loyd Elliot, he has a 226/234 cam that is very similar.
Quick Reply: Camshaft opinions
