headlights dimming/fading. WHAT IS WRONG?
Old 01-09-2011, 02:18 AM
cammedws6's Avatar
Default headlights dimming/fading. WHAT IS WRONG?
On my brothers 00 t/a the headlights will kinda dim/flicker when sitting at idle. The car starts right up, it dosnt seem like the battery is dying on me. what could it be?
Old 01-09-2011, 05:19 AM
Undertow74's Avatar
something is putting a unnecessary load on the vehicle. Does he have a stereo system installed in the vehicle? sounds to me like the alternator is going to ****. What i would do i perform a load test on the battery and check to see what the current volts/amps are at. should be able to go to a local shop/auto store and get that done. then i would do a alternator ouput test to make sure the alternator is charging correctly and that all your diodes are good. Hope this can help some......
Old 01-09-2011, 05:41 AM
myk
myk's Avatar
Wouldn't hurt to check your connections and cables, too...
Old 01-09-2011, 10:07 AM
Danny2tek's Avatar
sounds like corrosion in the harness....a known issue
Old 01-09-2011, 10:16 AM
metalmilitia606's Avatar
+1 on the alternator.
Old 01-09-2011, 12:30 PM
cammedws6's Avatar
a frind of mine ran a test on the charging ssytem and it checked out fine. maybe its a loose connection on the battery? ill have to look more into it. i just dont know how serious of a problem this is...
Old 01-09-2011, 03:51 PM
Swiat34's Avatar
Sounds like either an alternator problem or the alternator wire. Also check the battery cable ends for bad corrosion. Remove the bols from the cable ends to clean em out the best. Or as asked, too much bump in dat trunk!
Old 01-10-2011, 08:57 PM
cammedws6's Avatar
when i give it gas in neutral or park the battery indicator will drop after its decending rpm's at idle. i got the battery tested and it tested good. i also tested the alternator and it was fine as well. frusterating. any more suggestions?
Old 01-10-2011, 11:10 PM
Swiat34's Avatar
The wires to the alternator specifically then.
Old 01-10-2011, 11:42 PM
cammedws6's Avatar
okay ill have to check that out. is there any things i should look for? should it be very obvious or do i just need to check connections? ive never done this before.
Old 01-11-2011, 01:49 PM
cammedws6's Avatar
Ive come to the conclusion that this hapens the worst when the headlights are on. Im guessing the alternator is just weak and that it cannot handel the load? Does this sound logical? Im thinking i need to get a new alternator.
Old 02-12-2011, 11:16 PM
O2Form's Avatar
Mine does the same thing, I'm sure its the alternator. I'm going to try a new one soon. It a common problem.
Old 02-13-2011, 08:27 PM
99_ls1_z28's Avatar
its prob the alternator, had mine tested and it showed fine. But the problem was still there, until i replaced the alternator.
Old 02-13-2011, 10:20 PM
Swiat34's Avatar
Could be, but when you have an alternator replaced, the connections all get cleaned. Or at the least the removal and re-install would knock and corrosion off. So replacing the alternator doesn't rule out a connection problem.
Old 02-14-2011, 12:15 AM
LS6427's Avatar
Voltage regulator in the alternator is wacked. Replace the alternator. Mine is a PepBoys special, going on like 5 years old, it just started doing this last week. Lifetime warranty though.
Old 02-14-2011, 01:04 AM
Pitbull329's Avatar
Mine is doing the same thing. I'll look into cleaning the wires. Because it does it sometimes... like tonight, went to get something to eat, and the whole way there the headlights were fading. As I left the place, it didn't do it anymore.
The alternator wire can be replaced if needed right?
