Engine removal disaster
Old 01-09-2011, 04:28 AM
98Camarod's Avatar
Default Engine removal disaster
Has anyone ever had their dolly break why they were doing the removal? I did. It's supposedly rated to 1000lbs. It's a steel reinforced piece of ****. I had the assembly strapped to the dolly and as soon as I started moving it, the bitch snapped on the rear portion where the trans was. Then it snapped by the motor.
I had to drag the whole bitch out with a buddys truck. Then had to take a bunch of **** off just to get the hoist to put it in the garage.
I was smiling in the first pic because the bitch wasn't broken. I started this around 11 and didn't finish until about 530. It took way to long. I had some snags with the steering shaft, ground for the battery, and the brake lines.
I haven't got to look underneath to see what got destroyed yet, but something has to have been. Hopefully those were the wheels on the dolly. I'm going to make one this next go around. **** trusting those manufactures.
Old 01-09-2011, 05:51 AM
sjsingle1's Avatar
leave the wheels on and put a dolly on the back of the trans?
Old 01-09-2011, 05:58 AM
98Camarod's Avatar
The dolly was broken. You can see the marks in the driveway. I pulled it out from the side.
Old 01-09-2011, 10:21 AM
joe77's Avatar
quality chinese crap, sorry to hear it broke on you, hopefully nothing got destroyed
Old 01-09-2011, 10:33 AM
masterz28's Avatar
Oh damn. That sucks, engine work is like a bad relationship. Things will get better.
Old 01-09-2011, 10:52 PM
sxracerb25's Avatar
That sucks but that's a lot of weight to put on one dolly...I had a jack under the K-member, dolly under the trans and a dolly under each rotor...
Old 01-10-2011, 12:26 AM
dkbmxer002's Avatar
yup, it broke the exact same way on me, but i was using the cheap wood furniture one from harbor freight, so i can't complain hahahaha when putting it all back in i had to man handle everything back onto the legs of the lift since the cart thing broke, i used leverage and the cars wheels to move it around haha.
Old 01-10-2011, 05:37 AM
98Camarod's Avatar
Hey paul, did you end up making a dolly when you put it back in?
Old 01-10-2011, 11:44 AM
Pocket's Avatar
Had good luck using 3 wheel dollys. One per A-arm and one under the trans pan with some blocks to level it out
Old 01-10-2011, 11:45 AM
98Camarod's Avatar
Where'd you buy it from?
Old 01-10-2011, 01:11 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Thats why I always pulled from the top. You still need the Engine Puller. Just need to get the correct engine plate to pull.
Old 01-10-2011, 01:35 PM
Rich92RS's Avatar
Ouch!!!
Theres no harm in leaving the front wheels on right? I will be dropping my motor/tranny tomorrow and I plan on leaving the wheels on, while having just the tranny rest on the dolly.
Old 01-10-2011, 01:41 PM
dkbmxer002's Avatar
i thought that was you! haha, nah, i just used the legs of the lift as a dolly and manhandled the **** back under the car. the wheels still being on the suspension helped out alot. the biggest pain was getting everything over the little lip in my garage haha. the back two wheels on the hoist were hung up on the lip.
vette0009's Avatar
Make your own out of 2X4's
Or steel [ ]tubing
Old 01-10-2011, 02:10 PM
King Nothing's Avatar
Originally Posted by Rich92RS
Ouch!!!
nope no harm, just take your front bumper off so the shocks clear the front of the car and you can just drag it out . . . it's what i did
Old 01-10-2011, 02:46 PM
Pocket's Avatar
Northern tool
Leaving the wheels and pretty much everything still attached makes life easier
Old 01-10-2011, 03:06 PM
xxrillixx's Avatar
Im sorry, but you guys really thought 1 dolly was going to be enough?
I did 3, well actually a transmission jack and 2 wooden rollers from harbor freight, one under each aarm. The 1000lb load is considered over the entire unit. IE if you were to put a metal pate over it and add weight to the center. Its a distributed load, not at a single point... HUGE difference. Plus hell its japanese ****... id be amazed if it did hold 1000lbs. lol.
Quick math, Motor 450-500lbs, complete k member 300-350?, trans 100-150?... 850-1000lbs (being a little conservative)
I dont mean to add insult to injury, but the rollers are like $10. Im sure theres way more damage then it would have cost to get 2 more. Im just glad you didnt have a foot under it or something.
For people to use the excuse, "Thats why should you lift it out the top"... um, id MUCH rather it fall 2-3inches then have a bolt break @ 5 feet in the air. I think if your smart and over plan, either way can be safe.
Old 01-10-2011, 03:40 PM
dkbmxer002's Avatar
the piece of **** dolly i used would have worked if the wood didn't accidentally get soaked by fluids.
and yes, next time i take the motor out it will be going from the bottom, it was very easy imo.
Old 01-10-2011, 03:46 PM
01ssreda4's Avatar
xxxx is right has to be a distributed load for it to carry that much. I used 2 that were attached together using 2x4s across the top making them like one big one. I can drop the k member/car on it with no issues.
Old 01-10-2011, 04:01 PM
98Camarod's Avatar
I would have left the wheels on, but I planned on sliding the bitch out from the side. Didn't end up working. I know what you mean about the lip too. I've got an inch and a half step up.
If that k member and everything weighs 350 lbs I must be the worlds strongest man. I picked it up pretty easy and brought it into the garage with the motor and trans off of it. There's no way it was even tipping the scales at 900lbs conservatively.
In retrospect, I'm sure I should have bought two. But **** if I'm going to trust that **** ever again. I'm making my own.
