Please dont tell me its my fuel pump!
I woke up this morning and tried to start my car and it wouldnt turn over (like it wasnt getting any gas) I tried a couple more times to see if I could hear the fuel pump...NOTHING! It is freezing outside but i dont think that matters but I just put a brand new fuel pump in 3 months ago...is there any chance that it has kicked the bucket already?
Once you tried to start it the fuel system should already be primed if it primed at all. Mine does that, it will prime, and if it doesn't turn over, it won't re-prime. It could be the fuel pump, or the opti, or a number of things. Get a fuel pressure gauge and see if you get anything when it primes.
Ok I will check the fuel pressure and the relay and hopefully I will come up with a solution to this problem...I really dont want to drop that damn tank again lol!
Village Troll
The previous owner to my car just cut the sheet metal right where the sender/pump comes out of the tank, no dropping the tank for me, I just cut a piece of sheet metal and hinged it with a latch, cover it with carpet, no one will ever know the difference haha.
Me and my dad were going to do that just incase it went bad again but we not crazy about cutting into the car but now it sounds like a great idea haha! So if we need to get to the fuel pump we are going to do the trap door method.
One would think "turning over" means PHYSICALLY ROTATING, while "cranking" would mean the same thing.
Dunno...
Car has a NO START situation. It will CRANK however it will NOT START and RUN....
Have you sprayed carb cleaner or starter fluid into the throttle body?
Remove the shader valve cap and push the valve down if fuel just dribbles out you are most likely going to need a new GM pump or one from Racetronix a vendor here..... STAY AWAY FROM AUTOPARTS PUMPS & CHEAP EBAY PUMPS. I do not recommend the trap door mod on a daily driver however it does make the job about 10x easier.......If you do the trap door mod look closely at Ramairs job,make it clean and seal properly.......
