Will Fuel Rail Covers Fit W/Fast 102?
I'd say no. They wouldn't fit on my fast 90 wth stock rails. The humps on the fast are larger than the ls1 or ls6 intake, so it will take some grinding on the covers to get then to fit. But then the clips on the covers are made to fit on the stock ls1 rails. Idk how much bigger the ls2 rails are, if any. but they definetly will not clip onto the FAST rails. Maybe the GTO or C6 covers may be different......
With some modifications, ..., Yes.
I made of FRC's for a guy with the FAST intake.
I simply squared out the arches & raised them up about 1/4".
The c-clips on the underside are menat to clip onto the stock LS1 style fuel rail tubing. So, if anything different, or different position, ..., then plan on modifying.
Location: Your girl's back door giving her the long stroke while you're at work
Sean
When I first put the Fast 90 on my CETA the covers I had needed to be trimmed just a little bit but I never got around to it and ended up selling them
