BCM/Security Question
Old 01-09-2011, 09:36 PM
fknsmshn's Avatar
Default BCM/Security Question
When you guys buy a complete pull out from a car with a BCM, how do you get around the security stuff? I ask, because I wanna remove the BCM from my '98 Z28 but I cant find any good info about it. I figure you guys would know tho. Thanks.
Old 01-09-2011, 10:13 PM
busta9876's Avatar
for the f-body, you have two options.
VATS by-pass module, which will generate a pulse width frequency and when connected to the ''fuel enable'' wire on the LS1 PCM, will allow the PCM to fire the injectors.
Another option is to have the PCM programmed to disable the VATS.
-Brendan.
Old 01-10-2011, 06:43 PM
fknsmshn's Avatar
So, theres no wiring trick or anything I need to know? Just gotta have it tuned out?
Old 01-10-2011, 07:05 PM
Earl Filter's Avatar
The two options above are the only two.
Old 01-10-2011, 09:31 PM
fknsmshn's Avatar
Cool, thanks.
