lq4 swap no spark
Old 01-10-2011, 06:44 AM
m.rob28's Avatar
Default lq4 swap no spark
I just did an lq4 swap into my trans am and took out the ls1. I swaped over all accesories and all sensors. I'm also using the ls1 harness and ecm. When I went to start it there was no spark to any cylender. All it will do is just turn over. Does anyone have any idea what's going on? All the sensors that I swaped over from my ls1 to the 6.0 were all good. Thanks
Old 01-10-2011, 08:02 AM
LS1MCSS's Avatar
Did you remember to bolt on the ground wires to the back of the head?
Old 01-10-2011, 08:23 AM
m.rob28's Avatar
Yes I did. There were 3 ground wires going to the back driver head and I did bolt on all 3
Old 01-10-2011, 09:24 PM
m.rob28's Avatar
But that wasn't the problem. Anyone can help me?
Old 01-11-2011, 11:58 AM
m.rob28's Avatar
The motor turns over but it won't start. There is no spark coming out of the coil packs, but I put got more coil pacs to see if it was thos and they new ones had no spark either... any help would be greatly appritiated
Old 01-11-2011, 12:24 PM
LS1MCSS's Avatar
Is there 12 volts going to the coil packs, on the pink wire?
Old 01-11-2011, 01:13 PM
m.rob28's Avatar
Yes I was like 11.7v
Old 04-02-2012, 09:50 AM
68BBChevelle's Avatar
what did u end up finding on this issue? having same problem.
Old 04-02-2012, 11:06 AM
Redbull87's Avatar
Very possible the crank sensor or cam sensor isnt reading.if you have access to a obd2 code reader then plug it in and crank the car for a few seconds and it may give a code as to the problem.Id double check the crank sensor first...I had mine not plugged in all the way and did this exact issue.Good luck
Old 04-02-2012, 11:18 AM
Ive got it throwing a p1336 code which is the crank relearn code.
Old 04-08-2012, 09:47 AM
Redbull87's Avatar
Sadly you may have to do a case learn procedure and that means towin the car to a nearby dealership or dyno shop.You need someone with hptuners or a tech2 to initiate the crank sensor learn.Right now the crank sensor is not correctly reading the reluctor and wont give spark to the plugs.I dont know of anyway to cheat a case learn code but search tech and maybe there is something that can be done.
Old 04-08-2012, 09:50 AM
99fbodyTA's Avatar
Recheck your work and make sure you didn't miss anything first
Old 04-08-2012, 09:55 AM
Talked to my harness guy i was losing power on my ignition relay while cranking soon as i added power to it fired rate up. He also said it should of ran with the crank learn code.
Old 04-08-2012, 10:00 AM
Redbull87's Avatar
Thats good to hear,hhow does she sound?Ill have to keep that in mind if the ignition voltage is low it will give a no spark condition.Glad it worked out for you
Old 04-08-2012, 10:29 AM
99fbodyTA's Avatar
have you tried changing the crank sensor? i didnt research the 1336 code, but thats prob the source.
Old 04-08-2012, 11:53 AM
Didnt have to mine is still good just the power in my relay was holding me out. I got her running and now shes not showing any codes.
Old 04-08-2012, 11:55 AM
Thanks man. She sounds great, even better with the cutouts opened. I had voltage in the on position but none while cranking.
Old 04-08-2012, 04:19 PM
Redbull87's Avatar
Ahh the classic mix up of ignition wire hot during crank and accessory wire.Ive done it once before lol and chased it down after 2 days scratching my head.
Old 07-21-2014, 06:59 PM
11_silverado_noob's Avatar
which relay was it?
Old 07-21-2014, 08:03 PM
Originally Posted by 11_silverado_noob
which relay was it?
It was ignition relay.
Quick Reply: lq4 swap no spark
