LT1 to LSx head swap...?
Old 01-10-2011, 01:58 PM
hunt_1952's Avatar
Default LT1 to LSx head swap...?
I recently purchased a 95 Z28 convertable automatic with an LT1. This is my first late model project, and I don't know much about the LTx and LSx engine series. What if any interchangeability is there between the LT and LS engines? Will LS1 or LS2 heads bolt onto an LT1?
Old 01-10-2011, 02:00 PM
AChotrod's Avatar
Nothing will work besides the lifters
Old 01-10-2011, 02:23 PM
brettmc's Avatar
There was an article in car craft (i think) a few months back on an aftermarket SBC block that accepts LS heads.
Old 01-10-2011, 02:24 PM
IronOutlaw's Avatar
AC is correct. However lt1 heads are very good for porting and you can make big power with worked stock castings.
SexyTransAm's Avatar
bingo
Old 01-10-2011, 02:26 PM
brettmc's Avatar
http://www.worldcastings.com/product...ron-block.html
Old 01-10-2011, 02:45 PM
hunt_1952's Avatar
Thats a bit dissapointing. I was really hopeing for more interchange between LTx and LSx engines. What is the difference between the two heads? Bolt pattern? Bore spacing? Overall dimensions?
Old 01-10-2011, 02:48 PM
wrd1972's Avatar
You aint got a enough time or money to make LSx heads work on a LTx. In short, it wont happen.
Old 01-10-2011, 02:57 PM
hunt_1952's Avatar
Time and money are not a issue. I will be doing all the work myself. I did a chevy OHV head conversion on my model T speedster engine a couple years ago, that involves cutting the head in half, and a fair bit of machining. Nothing is impossible if you have the time, patcience, and desire...
Old 01-10-2011, 03:03 PM
the_merv's Avatar
LT is a 5 bolt, LS is a 4 bolt.
Old 01-10-2011, 03:25 PM
RamAir95TA's Avatar
LS1 head:
LT1 block:
Have fun with that. It's not going to happen, nor is it even worthwhile to put thought into HOW you could do it.
Old 01-10-2011, 07:12 PM
1961ba427's Avatar
and rod bearings
Old 01-10-2011, 07:15 PM
the_merv's Avatar
Power Steering Pump Bolts will work..lmao..
Originally Posted by RamAir95TA
LS1 head:
That's an L92/LS3 Head..
Old 01-10-2011, 07:18 PM
RamAir95TA's Avatar
Same thing.
Drak03's Avatar
"Its ok guys I 'modified' them to fit'. ::turns key, ???ummmm uh oh" lol jk man
Old 01-10-2011, 07:32 PM
the_merv's Avatar
If you want them to fit correctly then modify the K-member into a LS one, and get you some kind of Gen III/IV block..
Same thing.
No..the LS1 is inferior to that one...
Old 01-11-2011, 08:02 PM
NemeSS's Avatar
Same thing.
alrighty then....
Quick Reply: LT1 to LSx head swap...?
