adapter part question
Old 01-10-2011, 02:30 PM
BackInBlack02's Avatar
Default adapter part question
I have a 94Z with the stock Bose CD player. The cd player rarely works so doing the aux/mp3 mod wont work. Would rather keep the stock unit and fix it but can not find a place that will fix the cd player.
What is the adapter unit name/number, think the name is "Scoche" to use with an aftermarket cd player so that the bose speakers work correctly?
also, who sells it?
thanks.
Old 01-11-2011, 08:37 AM
Ungrounded Moderator
WhiteBird00's Avatar
The PAC OEM1 adapter allows installation of an aftermarket head unit into a Bose equipped vehicle.
Old 01-12-2011, 02:44 AM
Do you know if this will also work to install a 02 stock CD unit?
Old 01-12-2011, 07:13 AM
It will work with any head unit (factory or aftermarket) that has normal speaker-level output. It converts the speaker-level output to line-level (pre-amp) output for the Bose amps. Basically it's a fancy line out converter like the type used to convert speaker signal for input to a sub amp.
