A couple of LQ4 questions
Fist of all, bad lifter killed my ls1. Now i dont know what rout to take. Lq4 or forged ls1.
I found a 05 lq4 with 35k. Guy at the junkyard turned the truck on, oil pressure was good with no noises- sounded really good. Engine will be a full longbock with manifolds and pcm. Price- $1300. Good price? I'll be throwing the eps 226/230 112lsa cam. Considering going with some 243 milled, if ptv will allow and if its within my budget. Im assuming transmission and accessories just swap over.
Or, i could purchase a forged ls1 shortblock with 6k miles for 1900 and throw some stock 241's on there.
Go ls1? Wait for a better deal on an lq4 or lq9? Let me know what you think guys.
For info-Car is full bolton, ls6 intake, pt4k stall.
side note: we joined the same month of the same year and i have nearly 10x's the posts you have lol i'm a ***** i guess
Baldwin Park. Ill try and drop the price on an the forged engine then maybe ill be able to pull the trigger
Dont know if I mentioned it but the lq4 comes with coil pacs and all accessories.
thanks for the input guys. keep it coming.
24 tooth. What I need.
go with the lq4. mill the stock heads .030. get upgraded pushrods and springs. ls2 head gaskets. cam should work without ptv issues.
lq4 have 7cc spherical dish
but never hurt to check ptv clearance with any cam install.
317/243/799 heads share intake/exhaust runners cc and flow and valve sizes
chambers differ. 317 has bigger chamber
[QUOTE=1998LS1SS;14349553]Failed lifter took out cam, timing chain, sprocket, couple of valves and who knows what else. Getting it checked this weekend. After i get a quote for the fix ill make my decision
let me know if u go with the lq4. i would like to buy some of the stuff u may not need. pm me
Will do.
