m6 to a4 how to keep my reverse lights?
Old 01-11-2011, 01:15 PM
lttransam's Avatar
Default m6 to a4 how to keep my reverse lights?
hey guys i am currently in the process of converting over to a auto, and would like to know if anyone knows how to keep my reverse lights? thanks any advise would be appreciated!
Old 01-11-2011, 01:16 PM
tricked94camaro's Avatar
2 questions:
1. why are you going to auto?
and
2. whats the point of reverse lights? i havent had them for years lol
Old 01-11-2011, 01:22 PM
lttransam's Avatar
that helps me out zero. lol
1. because autos are faster and easier on parts. ask me how i know.
2. i do alot of backing in spots at night. so without reverse lights i would be screwed.
Old 01-11-2011, 02:01 PM
Gojira94's Avatar
http://shbox.com/1/1995_pcm5.jpg
24LT GRN (upper left quadrant, just right of the Parl/Neutral Position switch). You M6 PCM's program will need to be slightly modified to accept this signal...
Old 01-11-2011, 03:23 PM
lifeisgood's Avatar
i see you found u a trans. lol
good luck with the swap. u wont regret it.
the only way id have a 6spd now is if it was a dd. itd be alot easier on gas
Old 01-11-2011, 07:26 PM
lttransam's Avatar
lol yup a built 65e. i have most of the things i need, just want to figure out on these reverse lights lol. and yeah i am sure i wont regret it. mine is just a toy as well.
Old 01-11-2011, 08:52 PM
Wicked94Z's Avatar
just wire them to a microswitch on the shifter
Old 01-11-2011, 09:11 PM
henry172's Avatar
https://ls1tech.com/forums/automatic...d-writeup.html
Old 01-11-2011, 11:43 PM
lttransam's Avatar
i might end up doing it that way, if i cant find any other..
thanks!
Old 01-12-2011, 07:29 AM
flame's Avatar
If you use a factory auto shifter the reverse switch is built right in. Run the wires that went to the switch on the M6 up through and attatch to the new switch.
Old 01-12-2011, 12:24 PM
lttransam's Avatar
i have factory style shifter but it doesnt have any type of switch on it... is this the switch you are talking about?(not my shifter)
Old 01-15-2011, 08:00 PM
flame's Avatar
No that is the brake to shift out of park interlock. The switch is on the right side. 6 wires 2 for P/N starter circuit, 2 for reverse lights, 2 to pcm for P/N idle control.
Old 01-15-2011, 08:21 PM
lttransam's Avatar
yeah i actually found out that my shifter came with the reverse switch it was just separate. do you happen to know what wire on the t56 was the reverse?
Old 01-16-2011, 01:48 PM
flame's Avatar
I attatched pics of the reverse light plug on the M6 and the shifter plug for the A4. The wiring for the shifter plugs is
A-ground
B-org/black wire to pcm for P/N idle signal pcm pin 15 connector C (gray/clear)
C-reverse light brown wire from M6 reverse switch
D-reverse light lt/grn wire from M6 reverse switch
E-starter yellow wire from M6 clutch pedal switch
F-starter yellow/brn wire from M6 clutch pedal switch
Attached Thumbnails m6 to a4 how to keep my reverse lights?-reverseplug.jpg   m6 to a4 how to keep my reverse lights?-shifterplug.jpg
Quick Reply: m6 to a4 how to keep my reverse lights?
