Gears & Axles - finished explorer 8.8
southpaw0314
01-11-2011, 08:17 PM
since i couldnt find any 8.8 mustang rears for cheap and with the gear ratio i wanted i went with an explorer housing from a 96 with 4.10 gears.
http://i860.photobucket.com/albums/ab167/southpaw0314/1.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/2.jpg
luckily my friend that was helping had the hook up
http://i860.photobucket.com/albums/ab167/southpaw0314/3.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/4.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/5.jpg
sleeves because the 8.8 tubes are bigger then the 7.5.
http://i860.photobucket.com/albums/ab167/southpaw0314/6.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/7.jpg
first weld, my friend mike didnt like how it looked so he grinded it down and did it again.(he wanted the contact patch to be bigger)
http://i860.photobucket.com/albums/ab167/southpaw0314/8.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/9.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/10.jpg
southpaw0314
01-11-2011, 08:23 PM
I have to thank my friend mike for doing all the welding since i cant weld and i dont have the equipment.
http://i860.photobucket.com/albums/ab167/southpaw0314/11.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/12.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/13.jpg
lower control arm bracket for the mini ladder bar setup.
http://i860.photobucket.com/albums/ab167/southpaw0314/15.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/16.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/18.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/19.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/20.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/22.jpg
moser axles 31 spline
http://i860.photobucket.com/albums/ab167/southpaw0314/25.jpg
http://i860.photobucket.com/albums/ab167/southpaw0314/28.jpg
old 7.5 is out, it had 3.73 I was curious to see how much of a difference the 4.10 gears were.
http://i860.photobucket.com/albums/ab167/southpaw0314/27.jpg
now differential cover since the junk yard punched a hole to drain the fluids
http://i860.photobucket.com/albums/ab167/southpaw0314/29.jpg
its much quieter then the 7.5, i can barely hear it whine with my magnaflow exhaust.
dutinsss
01-11-2011, 09:06 PM
nice. i'm test fitting an 8.8 with 10 bolt brackets welded onto it right now. i wish i could have used 10 bolt tubes like you did but i got this housing already done so i'm going with it. what did you have to do to make those sleeves?
southpaw0314
01-11-2011, 09:12 PM
i just took the 8.8 center and the 7.5 tubes to the machine shop and got them made, they weren't the design that we discussed but they worked so i cant complain.
joe77
01-11-2011, 09:43 PM
I was wondering what you did for the abs? do you have a 3 channel or 4?
southpaw0314
01-12-2011, 06:16 AM
i have a 3 channel so my abs light is on, if you have a 4 channel you can get reluctor rings pressed onto your axles from moser i believe.
garygnu
01-12-2011, 06:44 AM
very nice build.you could sell some of them .
MUSTANGBRKR02
01-12-2011, 08:40 AM
I thought the explorer had a offset pinion?
Chronicle
01-12-2011, 09:06 AM
Stupid question:
What did you do about the torque arm?
southpaw0314
01-12-2011, 09:15 AM
it does but we offset it buy measuring the old 7.5 from pinion to flange and then making the 8.8 the same measurements, when i recieved the axles they were both the same length.
southpaw0314
01-12-2011, 09:18 AM
Stupid question:
i went with a mini ladder bar setup instead.(this isnt my picture but i did the same thing)
http://i860.photobucket.com/albums/ab167/southpaw0314/rearbuild024.jpg
Chronicle
01-12-2011, 10:21 AM
I'm gonna be honest, I've never heard of that before. You you explain to me how that works?
Jays_SSZ28
01-12-2011, 10:28 AM
So you just put all the tubes in and welded them up? No centering bar or anything?
It would be impressive to see someone doing it properly and you have no pictures of that so I'm assuming no.
southpaw0314
01-12-2011, 12:02 PM
the mini ladder bar keeps the pinion angle set just as the torque arm does
southpaw0314
01-12-2011, 12:07 PM
no i didnt use a centering bar the sleeves kept it centered and we used 2 squares against the flanges that the backing plates mount to and measured close on the square and then out as far as we could and it was less then a 1/16" difference.
sorry these are the only pictures i have of us fabricating the rear.
Oldsmobility85
01-12-2011, 01:07 PM
Thats cool dude good job. Keep us updated on how the car hooks. I am wondering how it will do without the forward lift of the tq arm.
Carter01
01-12-2011, 01:26 PM
Definitely a cool idea but i too question the absence of the TA... Let's us know how she does!
Chronicle
01-12-2011, 02:59 PM
I just realized you live in Harford County, I'm definitely getting a hold of you if I decide to go this route.
southpaw0314
01-12-2011, 05:11 PM
so far its been holding up its been in the car for about 3 weeks, ive been beating on it and have already made a 250 mile trip to school.
fastsspr
01-12-2011, 07:36 PM
Man cool build. I'm in the process of fabricating mine too. I used an Explorer rear to build mine.
I going to keep looking your progresss!
wfritts911
01-13-2011, 11:32 PM
Hows the mini ladder bar drive? cause my build looks literally exactly like yours. Machine shop even made the grooves in the sleeves too. Cause the only thing I'm worried about is the ladder bars handling like garbage and not being very street friendly.
-Will
southpaw0314
01-14-2011, 11:59 AM
-Will
on the launch the rear use to squat now instead it anti squats(i think it hooks better and i even went to 4.10 from 3.73). I dont fly around turns so i cant say how much of a difference it makes in this area.
dutinsss
01-14-2011, 01:42 PM
do you have any track times before you swapped to laddar bars to compare it to now? specifically 60 ft. times.
southpaw0314
01-14-2011, 06:10 PM
no but i wish i did to see what the difference was
