Switching Mufflers
Old 01-12-2011, 01:59 AM
SpeedFreak123's Avatar
Default Switching Mufflers
I'm wanting to go with SLP exhaust, but, I figure it would be cheaper to just cut the magnaflow out and replace it with a SLP LM1 muffler?
Will this work fine, I plan on having it welded in.
Old 01-12-2011, 02:29 AM
wysemunky's Avatar
If you have the magnaflow catback then by putting in a LM1 muffler you would lose one of your tailpipes. Have you looked into the TSP rumbler catback?
Old 01-12-2011, 02:56 AM
Oh, That is very true, LOL!
I'll look into the rumbler catback. Is it louder than LM1
Old 01-12-2011, 03:10 AM
wysemunky's Avatar
its like a mild steel version of the LM1 with a dynomax bullet instead of the LM1 resonater
Old 01-12-2011, 03:15 AM
Yeah, I looked them up on Youtube, they sound really good. I just dont wanna have to take out my maganflows and install the rumblers, i'm lazy...
My B&B tips should be here today, maybe i'll just weld those to my Magnaflow like i had planned before
Old 01-12-2011, 07:56 PM
97camaro383's Avatar
Default exhaust
on my camaro i just had them remove muffler and replace with pipe and still had two exhaust tips. you could do same with yours and just add the lm1 infront of the rear
Old 01-12-2011, 09:08 PM
pancho toco loco's Avatar
Believe it or not but changing out the cannon 3.5 tip on the magnaflow exhaust will alter the sound. will it be lm1 or rumbler loud no, but it is more pleasing. If you want loud and still keep the split exit I suggest the Pypes violator muffler. I bought one put it on and took it off after one start up, granted I did'nt have the tail pipes on BUT IT WAS LOUD. I'd say lm1 loud or slightly between a lm1 and 2. The rest of exhaust are long tubes and mufflex off road y pipe
Old 01-12-2011, 09:20 PM
BlackBird87's Avatar
x2. i would trade you my lm1 for your magnaflow if you lived by me
Old 01-12-2011, 09:29 PM
I've seen you posting on other threads, and your wheels are sick!!! I like the stock chrome's!!!!
I'm just gonna stick with my magnaflow, and get my B&B tips welded on.
Old 01-12-2011, 09:31 PM
Lawhead's Avatar
Good choice LM exhaust sounds SOOOOO bad
Old 01-12-2011, 09:34 PM
Another excellent choice would be a edelbrock muffler.
Old 01-12-2011, 09:41 PM
Thanks man. I think youre gonna like the way that turns out
Old 01-12-2011, 09:48 PM
Will the sound change?
Does anyone know what size piping the exhaust is?
Old 01-12-2011, 09:54 PM
If the new tips are bigger then the old ones yes
Old 01-12-2011, 10:13 PM
The exiting pipe on the magnaflow is 2.5in's. Try taking your tail pipes off of your magnaflow and leave the muffler in place. you will begin to see how changing the exiting pipes and tips w/ alter the sound
Old 01-12-2011, 10:21 PM
Do they unbolt from muffler, I thought they were welded? I was going to cut my Magnaflow tips off (theyre welded too right?) , and have my B&B welded on since both pipes are 2.5", I cant band clamp them.
Old 01-12-2011, 10:41 PM
What I was getting at was to remove the exiting tail pipes from the muffler, there just held on with U clamps. yes the tips are welded to the pipe but you can remove the whole pipe as one. Yes you can remove the tips by cutting them off ( this will save you from having a new tail pipes made up ) and have the B&B's welded on.
Old 01-12-2011, 10:59 PM
Ok. I will do that..
Quick Reply: Switching Mufflers
