Pontiac GTO 2004-2006 The Modern Goat
Intake besides FAST
Old 01-12-2011, 01:02 PM
04goat350's Avatar
Default Intake besides FAST
what was the other non metal or aluminum intake that was being made for the LS1/LS2 i think it was Weiand
Old 01-12-2011, 04:16 PM
gconnoyer's Avatar
Weiand is aluminum.
Other than FAST, I dont know of any other composite intakes.
Old 01-12-2011, 04:37 PM
Peetyz's Avatar
Fast was the only composite i believe as well and weiand was supposed to make a composite one called The street warrior but it never reached production sadly. but The LS6 intake is a nice piece. For free you could Open the 78mm Mouth to 85mm and install a professional products 85mm TB for about 200. I had that setup for a while.
The best bang for the buck is to sell your ls6 for 300-350 a get a used Fast 78mm usually around 500-600ish then port it and open the mouth to 85mm and add a 85mm Professional products TB. Custom Fast 85/85 setups are usually only a few hp down from a Fast 90/90 setup according to Tony Mamo.
Here is what my old 85mm ls6 looked like and same thing for my fast
A dremel tool is all you need just take your time and be careful
The biggest restriction on the old 78mm fast was the smaller mouth. Other than that it is the same internally as the 90 and 92. Now if you have the money the new Fast 102 unit is doing well but that requires an expensive TB.
Old 01-12-2011, 05:06 PM
MYSTIC-1SC's Avatar
Only aftermarket composite mass produced intake i know about it the FAST, and the only other one I heard about that was supposed to get produced was the Weiand Street Warrior and like Peetyz said it never made it to production.
Old 01-12-2011, 05:12 PM
Zmg00camaross's Avatar
The street warrior have fun trying to find one
Old 01-12-2011, 05:53 PM
Peetyz's Avatar
Lol it certainly got some hype up. I wanted one!
Old 01-14-2011, 04:54 PM
04GTODKH's Avatar
If money is not an option you can try this one from Harrop Hurricane.
http://www.youtube.com/watch?v=xJ7Dzk-4MDQ
Old 01-14-2011, 06:45 PM
ChefTA's Avatar
that's quite the monstrosity right there. How much green is that?? Proven gains??
Old 01-14-2011, 11:19 PM
04goat350's Avatar
yeah i saw this awhile ago this would be sick but expensive very expensive.
Old 01-14-2011, 11:29 PM
twelver12's Avatar
You could send your ls6 to tpis and they can put a 90mm snout on it, its still a pricey mod but its not a fast
Old 01-15-2011, 08:03 AM
Peetyz's Avatar
They had good results but the cost of that service would likely cost more than buying a used fast 90 and selling the used ls6.
Old 01-15-2011, 10:41 AM
twelver12's Avatar
that is true
Quick Reply: Intake besides FAST
