lifter and rocker selection
Old 01-12-2011, 04:26 PM
transmarobird91's Avatar
Default lifter and rocker selection
im building a ls1 keeping the stock bottom end building the top end. i have a ms4 and prc 227s with 675 springs, i need to select lifters and rockers, wondering what would be sugested for strength and power ratio's and brands.. your opinion will be apreceated. thank you
Old 01-12-2011, 04:37 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Comp 850's and stock rockers with the Comp trunion upgrade done to them!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-12-2011, 04:42 PM
JPH
JPH's Avatar
New set of OEM replacement lifters and a set of rebuilt rockers would be in order.
Old 01-12-2011, 04:55 PM
i was looking into the yella terras with stock ratio
Old 01-12-2011, 04:57 PM
JPH
JPH's Avatar
What is your cam lift and valve springs at the current moment that you are using?
Old 01-12-2011, 05:00 PM
lift is like 649 609 if i remeber correctlly... and i got dual springs rated for 675 lift
MYSTIC-1SC's Avatar
+1 one on the upgraded stock units from Texas Speed and the Comp 850s.
Old 01-12-2011, 07:38 PM
JPH
JPH's Avatar
Yella Terra #YT6645 is what I would look at.
